2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Rear Shock - 2017 Same as the Old Adjustable?
Old 10-23-2016, 06:38 PM
TonyGisCWO4's Avatar
TonyGisCWO4
TonyGisCWO4 is offline
Default M8 Shocks
Originally Posted by shimaze
TonyGisCWO4, what part number(s) did you buy? Did you buy 54000093 & 54000094 separately? Or did you get the 54000008 kit?
Bought the kit.
I am trying to determine if you used the new M8 shocks? I am also trying to determine if the 54000008 kit has both 54000093 & 54000094 in the box? Or is the 13” M8 shocks a bit different than the 13” shock from 54000008 that have been available prior to the release of the M8?
Both are in the kit. Same PN but the label on the shock is different; Prior had scale of Low/Med/High, new scale is numbered 5, 10, 15 and 20 with 3 additional tick marks so you know where you are adjustment wise and don't have to be riding down the highway thinking about it..LOL. Took pictures today right before test ride of a Limited. Operator's manual has new adjustment chart set up in a
table where you look at the rider's weight and follow it across to appropriate additional weigh carried and you will have the appropriate clicks. Not sure if it has more capacity or just more adjustment. Either way I like it better, wish I had known before pulling the trigger but still happy.
Attached Thumbnails Rear Shock - 2017 Same as the Old Adjustable?-img_3590-1-.jpg   Rear Shock - 2017 Same as the Old Adjustable?-img_3591-1-.jpg   Rear Shock - 2017 Same as the Old Adjustable?-2017-tour-pak-manual-preload-table-1.png
Old 10-23-2016, 06:51 PM
Harttoo's Avatar
Harttoo
Harttoo is offline
I have a 2017 Limited and I had the premium hand adjustable shocks on My 2014.I took them off when I traded.The 2017 right side shock spring is smaller than the previous hand adjustable.Mine is also starting to squeak at 2300 miles.
I liked the old style better.
Old 10-24-2016, 12:39 AM
TonyGisCWO4
I didn't even look but was wondering if there was any difference. I'll take a look next time I'm in a dealership for my own edification.
Bob Onit
02-25-2018 10:32 AM
1957buick
07-23-2017 02:01 PM
89FLHTC
EVO
02-26-2016 05:47 AM
HeroNtheShadows
03-25-2014 12:28 PM
Guntoter
Touring Parts
04-06-2012 11:29 PM
Quick Reply: Rear Shock - 2017 Same as the Old Adjustable?
