Is anyone using the new saddlebag lights that HD makes? I am talking about the led strip that mounts to the bottom of the hard saddlebag on a streetglide and is a brake/run/turn light. Sells for $150.Does it do a good job?
I have them. I also have the HD ElectraGlo saddlebag lights which stand out (in more ways than one) much more than the Stealth lights under the bags. You're also looking at the Custom Dynamics Fillerz & fender tip running/brake light along with a BAL tail light.
I have them. I also have the HD ElectraGlo saddlebag lights which stand out (in more ways than one) much more than the Stealth lights under the bags. You're also looking at the Custom Dynamics Fillerz & fender tip running/brake light arlong with a BAL tail light.
How are the stealth and bag lights connected? What are you using for the flashing of the brake lights!
In tandem with the factory plugs under the seat. It's all plug & play. I tried combining the wires from the ElectraGlo upper bag lights to the Stealth under bag lights, but no go. Upper are 3 wire and under are 4 wire. I couldn't get the combinations to line up, so I left them stock. When I remove a saddle bag, I have 2 connectors to dis-connect.
