2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
23" wheel
Old 11-08-2016, 07:19 PM
73impala's Avatar
73impala
73impala is offline
Default 23" wheel
When upgrading the front wheel on the bikes with abs are people still having issues? Is the Thunder-Max still the only option? I know some people got away with changing the rear tire out for running 21" wheel. I apologize if this is beating a dead horse.
Old 11-09-2016, 08:25 AM
Echo6 Sierra's Avatar
Echo6 Sierra
Echo6 Sierra is offline
I have a 21" Avon Cobra tire on my 2016 FLHXS; it came with the correct bearings and I have no issues. Got my package from Eastern Performance. The rim is made by Renegade.
Old 11-09-2016, 10:24 AM
JMC22's Avatar
JMC22
JMC22 is offline
Some found using a Dunlop tire on the front 21" wheel didn't throw the ABS - others (like myself) found that using a different tire (Commander II) did throw the ABS code.
For a 23" wheel - you'll need the Thunder Maxx - if I remember, if you exceed more than a 10% difference in size between front & rear tire you will throw the ABS code
Old 11-09-2016, 01:06 PM
CPT_Carrera's Avatar
CPT_Carrera
CPT_Carrera is offline
Performance machine wheels have something in the bearings that adjust for the wheel size so there are no issues with calibration at all. No thundermax device needed at all on their wheels. Mine is 23" performance machine.
Old 11-09-2016, 04:29 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
Arlen Ness make specific wheel size ABS bearings check it out...
http://www.arlenness.com/prodcat/ABSBearings.asp
but some wheel manufactures and or sellers ask if you have ABS now and will have the correct ABS Bearing for the wheel...nothing else needed.
Old 11-09-2016, 04:33 PM
barrygreen's Avatar
barrygreen
the adjustment is in the spacing of the trigger wheel in the bearing to adjust for wheel speed for the size of the wheel.
Old 11-15-2016, 06:51 PM
73impala's Avatar
73impala
73impala is offline
Thank you guys for the response.
TOE_CUTTER
Electrical/Lighting/Alarm
09-18-2018 11:54 PM
TOE_CUTTER
09-18-2018 11:45 PM
Shadowray
12-04-2015 06:52 PM
Hogpro
11-28-2014 02:41 AM
dwdet10
02-03-2010 06:08 AM
Quick Reply: 23" wheel
