2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Battery Charging?
Old 12-04-2016, 12:53 PM
No U Glider's Avatar
No U Glider
No U Glider is offline
Default Battery Charging?
Messing around installing and testing a new amp and speakers I've managed to drain my battery. What is the best way to charge the factory battery?
Old 12-04-2016, 02:53 PM
lyork's Avatar
lyork
lyork is offline
Use a 2 amp battery tender, but if it's completely dead....a 10 amp automatic would be ideal
Old 12-04-2016, 03:41 PM
RANGER73's Avatar
RANGER73
RANGER73 is offline
Received 5,921 Likes on 3,021 Posts
Best way is to ride it.
Old 12-04-2016, 05:33 PM
chopper_man's Avatar
chopper_man
chopper_man is offline
Received 1,603 Likes on 953 Posts
You got a 15 so you have a built in charger connection, should be on your left side down by your saddlebag. Might still be coiled up under your left side cover if your dealer never pulled it down. I'm partial to the Schumacher line of chargers. My current one I use is the Schumacher SP3. Great for both my RV and boat deep cycles as well as the bikes. Here's the one i use: https://www.amazon.com/Schumacher-SP.../dp/B00752TRP0
Old 12-05-2016, 02:53 PM
chrisg81983's Avatar
chrisg81983
chrisg81983 is offline
I agree with the Schumacher chargers and tenders. I use the same one as you, and feel the 3amp tenders work much better on keeping the battery healthy.
Old 12-05-2016, 11:18 PM
No U Glider
First winter with the bike coupled with being a dumb *** was the problem. Seems my Battery Tender Plus doesn't properly plug into the MOCO charging plug. Guess they want me to buy a MOCO product. Charger is now working properly when I connected it to the battery...
Thanks for the help...
Old 12-06-2016, 07:03 AM
MilesOfTexas's Avatar
MilesOfTexas
MilesOfTexas is offline
I have the CTEK MUS 4.3 with the tender adapter. It's an 8 step battery charger/reconditioner. Very simple to use, effective and affordable. http://smartercharger.com/
Old 12-06-2016, 11:23 AM
Rick58's Avatar
Rick58
Rick58 is offline
My '16 sgs plugs in just fine to my Battery Tender Plus.
Old 12-06-2016, 05:55 PM
padre14rk's Avatar
padre14rk
padre14rk is offline
Stage II
Ditto for my 14 Road King...
Old 12-06-2016, 05:59 PM
MURPHCC1's Avatar
MURPHCC1
MURPHCC1 is offline
Received 2,791 Likes on 1,359 Posts
If it's stone dead a CHARGER is in order.......not a tender......
Quick Reply: Battery Charging?
