Comm question.
Thanks again both of you for the input. Not sure I need to get CB as the other riders dont have CBs either and we will all go with same solution so the Senas sound like they will work better. And I prefer a wireless solution rather then a wired one.
As to the Freewire, whats a good mounting location, would like to hide it but i get that you may need access to the button on occassion
Vince
Did you make a call yet? Happy with the way you went? How's it working?
Larry
Larry
It comes with a handlebar mount and a "peel and stick" mount. Someone in another thread said they were going to use some HD com wires (No. 69200865, or a third party equivalent I think) to wire it into the little cubbie next to the radio; note that it would still need power for a "permanent" installation, or just recharge the battery. Another option is something like this harness from Sierra routed to a saddlebag, which appears to be bundled with a freewire if purchased from them. But since the SGS doesn't come stock with a com port on the tank, it may be overkill.
Sena is a great sys - however, if you or someone does not have the funds for it... I have a brand new Autocom in the classifieds plus the Autocom I pulled of my 2004 bike that the wife and I used and it still works great plus Many spare cables and headsets - all for a 'C' note - its a great way to talk to each other and not have to invest a fortune. Again, Sena is great put can be pricey.
https://www.hdforums.com/forum/touri...rice-drop.html
Just to clarify, this only adds the ability for the rider to communicate with the 6.5 radio. Harley does not have a setup to allow the rider and passenger to communicate with each other using the intercom on the Streetglide like they do for prior year models. There is a couple of threads in this forum where people have done this but they had to wire it up themselves and/or use the passenger push to talk switch module from an Ultra to get the CAN BUS to recognize the passenger connection. I also saw a thread where one person replaced the whole wiring harness with one from a limited just for that reason.
So far, the Freewire is working as advertised. BE SURE TO UPDATE YOUR HEADSET. I forgot to, and it would just not work right. I have not installed the extended harness yet.
I would say that my biggest complaints are 1. trying to find the right balance on two different volume ***** (bike head unit and the headset), 2. The phone call audio is a little quiet (could be an extension of #1) and I haven't figured out how to turn off side-tone on calls (I don't want to hear myself) and 3.when the bike sends navigation directions to the headset, the radio mutes (this may be more on the bike than the FW).
The last thing to figure out is how to make my 20s play nice with my phone when I ride my radio-less Dyna, without screwing up the settings for my Ultra.
TL;DR: Freewire is a great addition to my setup, especially when you factor in that I already owned the 20s.
PS.... sorry for the delay.
