Changing tuners good?
So I was just thinking.... my bike has a full stage one and was tuned by the dealer using the SE Super Tuner. Would I get different (better) results if I decided to try a power vision or fp3?
I never liked that my dealer told me they just use the super tuner and make it as good as it can get and that there wasn't any "levels" of settings that it could be set to. If that was thyou case then why does hd make 2 separate tuners?!
Anyway... could I see performance improvements or anything?
I have a Power Commander V on my 2001 Heritage Springer EFI and the FP3 on my 2014 FLHTP. I like the interface of the FP3 and the ease of programming. And the autotune. PowerVision has those things available as well, but at a much higher price. That said, the high HP guys all seem to be using the PowerVision, so there must be something about it that the heavily modified guys like better. For me the FP3 is everything the bike needs now (exhaust/intake), and with the type of modifications I am likely to do in the future (cams, heads, etc).
Ride Safe.
Ride Safe.
There has been a lot of discussions in regards to this. Check them out. When I was doing my research I learned there maybe two types. Basic one that works with factory large o2 sensors. Does a good job for the average tech or DIY person. The second uses a smaller sensor and possibly along with factory sensors to get a broader range of fuel to air mixture which the HI Tech Dyno people read on an average day.
Anyway I went with the FP3, plug and play, very easy install. It allows you to use your droid or Iphone to adjust settings of your bike. The FP3 once calibrated to the bike is married to that bike only. You can make a lot of adjustments to your bike via the phone. I am happy with it and it has helped my bike performance a lot.
Recommended would be a flash tuner (SEST, TTS, PV) but really lies in the hands & expertise of the tuner & which software his skill level is in...how close are you to here? http://www.docsperformancetuning.com/
For those that think using a FP3 is tuning your bike , try taking you bike to a Skilled Dyno Tuner and I bet that FP3 will find a New Home in the Trash Can!!
Mr D (12-16-2016)
Sound advice right there but let's not forget them boy's from J&B Performance in East Tn as far as tuning goes either !!!! If the dyno tuners are good at what they do then the tune they will give you with a Power Vision or the equivalent of will out weigh the FP3 2 to 1 I'll assure you !!
I have owned HD super tuner and still have the software.I had an FP3 on My last bike.I have the HD street tuner on the bike, I now own.Comparing the numbers of all 3 tuners,I find them to be identical.So buying an FP3 will do nothing for Your tune.If You buy the software and cables and have any knowledge of tuning,You can make the bike perform better.Easiest upgrade is changing AFR to 14.0 and do a Smart tune with the Super tuner.
If this is all beyond Your skill,then Dynotuning is the answer.You do have to understand that the maps for all tuners are made by dynotuning.So they are all similar.The tuner tries to get performance and gas mileage at optimum.If You tune for great perfomance ,You lose gas mileage.Hope this helps.
glide_n_around
10-01-2013 02:44 PM
