XM Radio w New Antenna
#31
Not to hijack this thread, but I have the XM module/antenna 76404-06 that works on 2006-2013 models just sitting in my shed. I know it needs the Non-Ultra Overlay Harness (I BELIEVE I have that as well, but I wired in the Iron Cross Ipod adapter into the harness) in order to interface with an FLHX...not sure what you're riding. I attached the Instruction Sheet for my module; read it over and see if you'll be able to use it.
If it's something you can use, make me an offer (BTW: I can't PM you).
PM Sent (included an email address in case the PM still doesn't work)
#32
#33
Stick_FSMC (01-18-2017)
#35
I bought the XM unit when I first got my 14 and i rarely use it because the reception is so bad. After reviewing this thread and others, was thinking it would be worth it to try a new antenna and pulling the antenna from inside the fairing. Thoughts on going new HD antenna or the microdot that baeseman1 mentioned? Any comparisons? If I do it I should also relocate the antenna to the side of the vent as many of you have?
#36
#37
#40
They stayed, Hard Rock is no problem. I grew up in the 60's, listening to everything from early Rock & Roll, through Psychodelic/Acid Rock, Heavy Metal and on up to 80's Hair Bands. I think Hard Rock falls in there somewhere.
