Fob dead even with new battery
02-21-2017, 12:22 PM
Just like the title says. One fob stopped working even with a new battery. Other fob still works fine. Any ideas before I return it?
Thanks
02-21-2017, 12:49 PM
Check the battery polarity, I double checked and still got it wrong, worked fine after I flipped it.
02-21-2017, 02:28 PM
Yes, I should have mentioned that was the first thing I checked. Appreciate your input though.
02-21-2017, 02:52 PM
If you have not done so, try putting the battery from the working fob into the non working one, in the rare event you got a bad new battery.
02-22-2017, 03:48 AM
Plus one on having the battery upside down.... don't ask but lets just say I bought the service mgr a bottle....
Be Safe JIM
02-22-2017, 10:52 AM
No luck. Swapped batteries with a known good one. Double and triple checked polarity. Looks like it's going back.
Do they need the bike? It's raining like hell around here.
02-23-2017, 05:25 PM
Solved....who knew there were different types of batteries. Fob needs a CR2032 and I was trying to replace it with a CR2025.
They are both the same size and appear identical.
Live and learn.
02-23-2017, 05:33 PM
Well I'm glad you solved the mystery and for just the price of a battery
02-23-2017, 09:38 PM
Interesting - you mentioned earlier that you swapped the battery with a know good one. Someone had suggested you use the battery from the working one. Is that not what you did?
02-24-2017, 10:09 AM
Glad you got to the bottom of the problem..
My FOB has the CR2032 in it as well with differences being:
CR2032 - .79" Dia x .13" Height, 3 Volts, 230 ma-Hrs (Longer life)
CR2025 - .79" Dia x .1" Height, 3 Volts, 165 ma-Hrs (Shorter life)
So the shorter battery(CR2025) prolly wasn't making contact inside the FOB...
cprhed
03-25-2019 05:42 PM
FFIrish
09-25-2015 08:28 AM
ch54
11-01-2014 01:31 PM
mang0
02-25-2013 06:02 AM
emwolb
12-27-2012 12:49 AM
