Heated Gear
I have a 2016 Ultra Limited that came with the heated grips. I've added a heated seat. My wife & I are considering buying heated jackets or jacket liners. Is there any danger of us overloading the charging system on this bike? Or can it handle this with no problem. I don't want to start burning up stators every few months. Thanks!
Gloves: 2.2 per pair
Socks: 2.2 per pair
Jacket: 6.9 each
Pants: 4.0 each
Vest: 4.2 each
OP
I'd say your bike will handle a couple pairs of heated gloves and jacket liners. Adding in pants liners might cause you to have to kill your running lights at low speed and/or turning the clothing down or off at rpms of less than 2k. The stator doesn't produce max amps/watts at lower rpms.
Off the top of my head
Gerbing gloves 22w a pair
Jacket liner 77w
Pants liner 90w
Times that up by how many sets you're gonna use and see what reserve you have to work with. I would by no means sit in a traffic jam running all that juice.
I have spent quite a bit of time researching heated gear and decided to wait until I upgrade the charging system. The stock charging system will work with the heated gear while cruising down the road. It's when at idle at lights that's the issue. HD makes an upgraded one that is only 4 amps more than stock, but the big difference is that it makes the needed power at idle.
http://www.harley-davidson.com/store...harging-system
Engineered to provide 30% more power than the stock system at idle
With 54 amps of output at 4,000 rpm, accessories will operate at their peak performance - no more dimming lights, reduced audio performance or under-performing heated gear
Recommended installation anytime a multi-amp audio system is installed in order to achieve the full capacity of your audio system
Recommended when installing heated seats, heated gear and other higher draw powered accessories
Maximum power output of charging system is 793 Watts (based on constant voltage cold data)
Ideal for heated clothing, heated seats and grips, decorative lighting, and high-output audio systems place added demand on the motorcycle's charging system
Complete kit includes high performance rotor, stator, voltage regulator and all gaskets and hardware required for installation
Stock on select CVO™ Touring models
My wife got heated gear for her bike. I saw how much more comfortable in the 30's than I was, and how much less bulky clothing she had on.
I got heated gear. Sure glad I did, the teens are comfortable. I go out for rides in the 20's and will put 200~250 miles on.
Guess I'm not a real biker. I average 24K a years since 09. My 4 month old CVO Street glide has 10,3xx miles on it. I have a King I ride also.
First, ditto all the reply to the dork riding in 17°f comment...
On heated gear, here's my experience...I have the full Gerbing suit. Jacket, gloves, pants and socks. I have run them all along with the grips and seat and it does draw more than the stock 2014 FLHTK alternator will put out, but not by too much and I've never been left with a low battery...
But here's another thing I've found with Gerbing gear...
1.) +10 on the (made in the USA) Gerbing jacket. Works great, heats VERY nice.
2.) 5 on the gloves. Sent them back twice because the heat was marginal to poor. Not worth the $$. Rarely wear them anymore.
3.) 5 on the pants. Same issue as gloves, poor heat mostly on the top of my legs. Not worth the $$. Rarely wear them anymore.
4.) 2 on the socks/booties. VERY uncomfortable. Very localized heat mostly on the toes, even burned my toes (left heat marks). Not worth the $$. Rarely wear them anymore.
Jacket was made in the USA, all the rest of the high prices crap came from China! This when Gerbing was suppose to be manufacturing here in the USA.
Give Gerbing serious thought before purchasing in my opinion.
Check out http://www.heatedclothing4u.com/
He is my local (Maryland) Gerbing/Gyde guy. He knows his ****, so give him a call. He also does discounts for military, vets, etc.
I've ran the jacket/pants/gloves/seat/grips on my '14 for days on a trip and made it home without any issues.
I run 2x Fosgate TM400x2 amps on my bike and my heated gloves. Haven't had a chance to run with my socks yet but don't expect any problems at all.
Had the gloves all the way up, and the 2 amps running while charging my wife's phone without issue.
