For those who did ape install themselves
#31
Here's how I ran my wires in my 12" KST Mayhems
i pulled the 6 pin tbw plug and then put shrink wrap around the green connector so it wouldn't pull apart. I left the white connectors on the can bus harness.
I use about 8" of shrink wrap at the end of each harnes that I pull. This protects the wires and plugs as I work them thru the bars, especially the ones with peaks at the top. The shrink wrap also makes for a good attachment point for my pull cable. Just leave about 2" extend past the harness. I flatten it then put some holes to snake the cable thru then wrap the cable for about six inches and secure with electrical tape ove those six inches.
I used 3 pieces of fishing wire to eventually pull my steel cable thru, 1 on the left, 2 on the right. (Since I only have enough steel cable to pull one harness at a time). Just put a fish weight at the end of each fish wire and let gravity do the rest. For each harness pull, I first use the fish line to pull the cable thru. Then I use the cable to pull the harness.
On the right side I pulled the can bus harness first, then the tbw harness. Since I don't use heated grips, I just folded the pigtail with black connector back and secured with a zip tie. I save the other half of the heated grip harness if I need in the future.
starbiker99 (02-23-2017)
#32
#33
#34
jordanball33
07-01-2010 12:52 AM
