Wiring into HD-LAN (can bus)
I'm getting ready to install a Denali PowerHub2 fuse block on my 2014 Street Glide Special.
I will wire the hot side of the Denali PowerHub2 fuse block directly to positive post of battery and the negative side of the Denali PowerHub2 fuse block directly to the negative post on the battery.
My questions is I have a switched side to the Denali PowerHub2 fuse block but because of the HD-LAN (can bus) I do not know what wire on the bike to tap into without messing with the HD-LAN (can bus).
Can any one suggest a wire to use that does not interfere with the HD-LAN (can bus)?
