2014+ Touring Models This Section Is For Rushmore/2014+ Touring Models Only
Stock header with CAT removed- equivalent
Old 04-05-2014, 05:27 PM
LilWick's Avatar
LilWick
LilWick is offline
Default Stock header with CAT removed- equivalent
What aftermarket header would the stock header with the cat removed be equivalent to? I am trying to figure out which PV-2 tune would be best. I have the Fuel Moto stage 1 AC, de-catted stock header and the American Custom Revolution mufflers.
Old 04-05-2014, 06:47 PM
Wmitz's Avatar
Wmitz
Wmitz is offline
I use the Fullsac Sport pipe. They cut out the cat make squish chamber add some length to one pipe to eliminate the cross talk for the sensors and weld it back up to a stock head pipe. They claim to make 1 hp less than the custom pipe. You can buy it outright, or buy and exchange for less money. Heat shields fit like stock. I have had no issues.
I have a 12 RG, check to to see if they have a pipe for the 14's, it should be the same
Old 04-05-2014, 07:25 PM
Harttoo's Avatar
Harttoo
Harttoo is offline
Jackpot 2-1-2 from Fuel Moto.I had this one on My 2012 Limited.Nice performance.
Old 04-05-2014, 07:45 PM
LilWick's Avatar
LilWick
LilWick is offline
i am not looking to buy a head pipe. i am trying to figure out which tune will work best with my de catted pipe and setup.
Old 04-05-2014, 07:54 PM
xhere's Avatar
xhere
xhere is offline
Not sure which aftermarket header would resemble the stock configuration. I'm assuming your tuner list various pipe configurations except stock? The v&h power dual header is a 2-1-2 like your stock header, biggest difference may be o2 location. If that is an option on your tuner, probably a good starting point.
Old 04-05-2014, 08:11 PM
SafetyMan's Avatar
SafetyMan
SafetyMan is offline
Call Jamie, he can tell you where to start.
As long as you're in the ballpark, it's simple to autotune from there and get it right.
Old 04-05-2014, 08:51 PM
toddjsn's Avatar
toddjsn
toddjsn is offline
I use the power duals map for my de-cat
Old 04-05-2014, 09:55 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Why not call FM's tech line and ask. That's what I did.
KidGlide
Milwaukee Eight (M8)
28
10-07-2018 02:27 PM
Psycho Dave
07-12-2017 02:27 PM
SACHD
Exhaust System Topics
07-29-2016 10:33 AM
harleytq
10-08-2014 03:02 PM
C.H.L.
Touring Parts
03-17-2013 10:26 PM
Quick Reply: Stock header with CAT removed- equivalent
