2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Stage 1 Air Cleaner with Stock cover used
Old 04-06-2014, 11:29 AM
badlandr's Avatar
badlandr
badlandr is offline
Lightbulb Stage 1 Air Cleaner with Stock cover used
I looking to do the Air Cleaner upgrade and want to keep the stock air cleaner cover.
What do you think is the best Stage One air cleaner to use with the Stack cover?? Why?
Thanks!
Old 04-06-2014, 12:12 PM
frankegd's Avatar
frankegd
frankegd is offline
HD has a stage 1 air filter combo for about $149 that will use the stock cover. It will replace everything else, including the '103' shield, but you can still use the original one.
I installed it. It's a bit of a pain the get the braket out, that connects the front and rear cylinder, has some clips for wires attached to it. Other then that it's an easy install.
Thank you
FrankEGD
Old 04-06-2014, 12:20 PM
Jim R.'s Avatar
Jim R.
Jim R. is offline
The fuel moto kit leaves that PIA bracket in place, took all of 20 minutes to install..worked well for me
Old 04-06-2014, 01:39 PM
Triig's Avatar
Triig
Triig is offline
I bought the HD before Fuel Moto had theirs for sale. The HD one does everything it needs to do, and I got a 20% discount on it from my dealer. I used some painters tape on my gas tank and cylinder heads while removing the bracket, no need to take the tank off like the instructions tell you to.
Old 04-06-2014, 06:19 PM
RSDUDA's Avatar
RSDUDA
RSDUDA is offline
mine is on order
Old 04-06-2014, 06:49 PM
dad311's Avatar
dad311
dad311 is offline
Originally Posted by RSDUDA
mine is on order
Mine got installed this weekend. 20 minutes to install and the 20 minutes included drinking a beer.
Old 04-08-2014, 10:07 PM
TheLazyC's Avatar
TheLazyC
TheLazyC is offline
Thanks!
I upgraded to the Streamin Eagle Stage One intake and it uses the stock cover, but has a upgraded badge that you do not have to use. It can be added and removed as it has velcro backing.
Old 04-08-2014, 10:39 PM
jcapps's Avatar
jcapps
jcapps is offline
Me too, I like the SE badge
Old 04-10-2014, 07:32 AM
badlandr's Avatar
badlandr
badlandr is offline
Thanks for the input!
Old 04-10-2014, 07:38 AM
klink58's Avatar
klink58
klink58 is offline
Default 2014 Road King
I had mine installed along with street cannons and the program.She runs sweet it think.Its still in the basement with only 800km on it from last fall.
Quick Reply: Stage 1 Air Cleaner with Stock cover used
