2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Yippeeee! My PTT problem is fixed at last!
Old 04-25-2014, 07:42 AM
44492001's Avatar
44492001
44492001 is offline
Wink Yippeeee! My PTT problem is fixed at last!
After 7500 mi on my FLHTK, my PTT issue is resolved.
The problem was that with narrow/smaller hands, when I pushed the CB's PTT button, I have to keep a grip on the throttle as well, which was causing the squelch setting to change every time I pushed the PTT.
My mechanic pulled off the PTT button from it's stem, set the squelch at mid range, and slid a rubber grommet down the stem. This makes it very difficult (but not impossible) for the stem to move up and down and affect the squelch. He then put the PTT thumb button back on.
Limiting the up/down range of the stem prevents the squelch from changing as I do the PTT maneuver....Hooray!
Old 04-25-2014, 07:47 AM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
And with small/narrow hands, you have no problem pushing the PTT button while keeping your hand on the throttle? That seems to be the major problem for most...
Old 04-25-2014, 07:55 AM
NiteOwlNY's Avatar
NiteOwlNY
NiteOwlNY is offline
I don't have small hands and it's a PITA to use the PTT button without affecting the throttle unless I have the CC on or just use my left hand!
Old 04-25-2014, 08:27 AM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
OP has given me an idea though, maybe a rubber grommet or washer (similar to a garden hose washer) slipped over the end of the PTT switch. Might extend the edge a little and make it easier to reach the button, even a little bit would help. I know the button has up and down and push in movement, don't remember if there's a side to side (right-to-left) function. That might be the only problem, I'd be pushing on the right side of the button/washer. I'll try it later...
Old 04-25-2014, 01:55 PM
jkane13's Avatar
jkane13
jkane13 is offline
I am not happy with the positions of those buttons either. Trying to change the radio favorites requires using the right hand. That means maintaning throttle and sliding my hand over to reach the toggle that's even closer than the ptt. I often end up accidently rolling the throttle on suddenly. I thought it was just me! Can't wait until we start doing group rides and I want to use the CB. I can only see this getting worse with the longer reach.
Old 04-25-2014, 02:50 PM
44492001's Avatar
44492001
44492001 is offline
Yeah...I think the PTT switch position on the right is pretty dangerous. I've written to HD, given them input via their Advisory Council, and talked to the Product people at Daytona about it. Sure hope they move it back to the left side in coming years. But for now.....I'm glad the fix works for me!
Old 04-25-2014, 11:25 PM
ke5rbd's Avatar
ke5rbd
ke5rbd is offline
Ever heard of cruise control. I use mine regular and not a problem with the buttons. My 10 had push to talk on left and it was next to impossible with the clutch pulled in or while shifting. Since you don't use the cruise while clutch is in and shifting it made since to me the moving to right with the PTT. I had a problem using the cruise on the 10 and trying to hold the throttle. Got better with that as time went on. To each his own I guess.
Old 04-26-2014, 07:49 AM
44492001's Avatar
44492001
44492001 is offline
Yeah. It's not a problem when in Cruise Control and you can release your hand from the throttle. Seems like most of my CBing occurs when not, though.
Old 04-26-2014, 08:15 AM
IUOE ROB's Avatar
IUOE ROB
IUOE ROB is offline
Riding in a group it's very difficult to use the cruise but that is when you use the CB the most, to communicate with other riders. And were you really talking on the CB when you were changing gears? Changing gears and clutch pull is a momentary action whereas throttle control is usually a constant action (except when stopped). And I don't understand your statement about the problem using the cruise and holding the throttle, if you were using the cruise why would you need to hold the throttle?
Old 04-26-2014, 10:57 AM
NiteOwlNY's Avatar
NiteOwlNY
Cruise Control is very difficult to use when you're in a group ride or you're coordinating some kind of on escort (Patriot Guard, etc) because you're not running a constant speed.
You only have to give the CC button a quick tap, you have to hold the PTT button in while talking.
That button for the odometer would have made a perfect PTT button!
Quick Reply: Yippeeee! My PTT problem is fixed at last!
