2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Installing Switch for Auxiliary lights
Old 06-07-2014, 06:39 PM
sal50's Avatar
sal50
sal50 is offline
Default Installing Switch for Auxiliary lights
Hi,
I am thinking about installing Auxiliary lights on my 2014 Street Glide Special. Does the ignition switch need to be removed to install the switch on the dash or does the dash just slide out when the side screws are removed?
Thanks in advance.
Sal
Old 06-07-2014, 06:41 PM
dawg's Avatar
dawg
dawg is offline
Received 2,945 Likes on 1,705 Posts
Switch needs removing in order to take off the panel
Old 06-07-2014, 06:48 PM
sal50's Avatar
sal50
sal50 is offline
Thanks for the quick reply. Is it necessary to have the alignment tool for the ignition switch or can the fork be left in the locked position and still allow the dash to be removed and the installation of the Aux light switch?
Old 06-07-2014, 07:34 PM
dawg's Avatar
dawg
dawg is offline
If you don't mess up the tumbler alignment, you don't need the tool.
Old 06-08-2014, 02:35 AM
Granpita's Avatar
Granpita
Granpita is offline
I just went through this. I didn't pay attention to the alignment and was faced with buying the alignment tool which is absurdly expensive - pushing $100, I think. I ended up making one from a short length of 1/4" copper tubing. If you ended up needing one, I can send you a picture of mine. Not as pretty as some of the others I've seen, but it works well.
Old 06-08-2014, 09:10 AM
smiller29's Avatar
smiller29
smiller29 is offline
6th Gear
FYI on the 2014 models you do not have to remove the ignition switch just the screws on the sides of the panel.
Old 06-08-2014, 03:37 PM
frankegd's Avatar
frankegd
frankegd is offline
That's right. Done it a few times, little bit of a fumble, but no need to get the ignition switch out.
Thank you
FrankEGD
Old 06-08-2014, 05:33 PM
Pewter's Avatar
Pewter
Pewter is offline
I fitted auxillary lights and did not need to remove ignition switch. Just undo the two screws and the panel will come away or you can reach up behind it and undo the two screws holding the blank switch.
Old 06-08-2014, 09:11 PM
jimmmya's Avatar
jimmmya
jimmmya is offline
I also added the Ultra lights on 14 SGS the switch panel is easily removed by the two screws
Old 10-01-2015, 08:47 AM
TexasMotorcycleRider's Avatar
TexasMotorcycleRider is offline
Is the switch panel already installed with the blanks or does that need to be purchased with the $119.99 kit?
quickster47
09-10-2012 11:37 AM
phil41
08-16-2012 06:15 PM
Calwoodbutcher
EVO
09-22-2010 01:31 AM
Hrlyrider
06-27-2010 02:08 PM
DinosauRider
03-28-2008 04:50 AM
Quick Reply: Installing Switch for Auxiliary lights
