2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Progressive 944 SERIES ULTRA TOURING SHOCKS?
Old 02-13-2016, 11:31 PM
ROCKOUT Rocker Products
ROCKOUT Rocker Products is offline
Sponsor
Received 1,628 Likes on 1,176 Posts
Biggest mistake I hear with 944's is not setting them heavy enough. People think they are riding stiff, when in truth they're bottoming & running on the bump stops. Start from the stiffest position & work your way softer, not the other way around.
I have the heavy springs, I'm 230..... I have them adjusted to 3 lines showing.
Give it some time... you'll like them.
For ROCKOUT information & purchasing please click the links below...
__________________
NO, they DON'T all do that!
Also on amazon.com...
The following 2 users liked this post by ROCKOUT Rocker Products:
RandyJK (07-09-2017), sirrat007 (06-21-2017)
  #42
Old 02-14-2016, 03:52 AM
DesertCamper's Avatar
DesertCamper
DesertCamper is offline
Thanks for the tip. I've got them set at 2 lines showing. A friend is coming over to help me measure tomorrow. We'll see how that sets up. But I think you're right, I'm going to have to fiddle with them until it feels right. Already went for a ride tonight with the new settings and a huge difference was noticed. Tight, but controlled. Some others have said there's a breakin period. I'll give it time.
  #43
Old 02-14-2016, 08:34 AM
ConfuciusSay's Avatar
ConfuciusSay
ConfuciusSay is offline
Received 2,528 Likes on 683 Posts
Great thread as I am considering putting my 944's on my 14 Limited. I had the 944's on my 09 Street Glide and put the stock air shocks back on when I traded the Street Glide. I'm just okay with the stock air shocks on the Limited, and in fairness, I have not been able to put a lot of miles on the bike (bought it "used" in October 2015 with 811 miles). I have the 944's in a box on the shelf. I was very happy with them on the Street Glide, but that bike came lowered. I am concerned about any clearance issues going to a lower shock. Any thoughts?
  #44
Old 02-14-2016, 10:10 AM
Sponsor
The Limited Low and the Ultra Low come with 12" shocks from the factory, no problems.
  #45
Old 06-08-2017, 08:08 PM
Todchi's Avatar
Todchi
Todchi is offline
Stage I
Which Ohlins shocks did u put on your ultra.
i have a 2015 ultra classic low and I was thinking about the 12" (which are 11") to
replace the stock shocks. I am hearing the Ohlins might be better. I am only 5' 2" tall
and would like to lower a little, but don't wanna harder ride than it is.
  #46
Old 06-21-2017, 03:43 PM
sirrat007's Avatar
sirrat007
sirrat007 is offline
Originally Posted by Portert
If you have a lowering kit on your 14 Street Glide Special check the tire side of the bags. I had mine lowered with Bagger werks adjustable lowering kit #598157 and when I took my bags off to clean it the shocks were eating a hole into both the bags. My dealer installed it and have replaced the bags. They told me lowering it wouldn't cause any problems!! They said they have installed this kit on several other 14 SGS but the dealer said they haven't had any others with this issue but I am thinking maybe I am the only one to take the bags off to clean it. If anyone else is having this problem please let me know!!
Thanks
My lowering kit came with fatter washers to space the shocks out a little. I have no isues with the shocks hitting the bags. sounds like either the kit you had used too fat a washer or the guy that installed did it wrong. Might want to check his work you could easily replace the top shock washes with something a little thinner.
Good luck......Mike
  #47
Old 06-21-2017, 04:41 PM
cycle7447's Avatar
cycle7447
cycle7447 is offline
Received 1,696 Likes on 1,029 Posts
This may have been stated here - but just in case. I have a 2014 Ultra Limited. Talked to Progressive about the 944s - was told, they are OK for the Road Glide but, if you put them on a limited, you should install them upside down.
Hey, just passing along what they told me - you can call them directly.
RandyJK (06-21-2017)
Papa412
04-11-2019 04:26 PM
sworks
18
07-10-2016 07:35 AM
antman27
02-10-2015 12:49 PM
EasternPC_Forum
Vendor For Sale Classifieds
11-20-2014 05:27 PM
Urb
08-05-2014 05:51 PM
Quick Reply: Progressive 944 SERIES ULTRA TOURING SHOCKS?
