2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Fp3 installed today
Old 07-30-2014, 06:55 PM
Shepherdboy44's Avatar
Shepherdboy44
Shepherdboy44 is offline
Default Fp3 installed today
Installed a fuel Moto stage 1 air cleaner, fp3 today. V&H tech support said their high output slipons were a close match to my RC exhaust slipons with my 3 inch baffles. Flashed ECM with stock head pipe, high output slipons, and set throttle progressivity to moderate setting. Wow! Woke up the bike! Much improved throttle response, a little more power felt on the butt dyno. But best of all, didn't seem to run as hot anymore. And it was a hot 90 degree Florida day here today. Very satisfied the way she runs now. Programming the map was pretty simple on my IPhone 5. Hats off to Vance & Hines for their Fuel pack 3. I'm impressed.
Old 07-30-2014, 07:42 PM
20streetglide14's Avatar
20streetglide14
20streetglide14 is offline
im set on this aswell, it seems to be a great setup
Old 07-30-2014, 07:54 PM
steveg56's Avatar
steveg56
steveg56 is offline
How did you set the throttle response?
Old 07-30-2014, 09:02 PM
barrygreen's Avatar
barrygreen
barrygreen is offline
It's in the edit map
Old 07-30-2014, 09:37 PM
TcHunter's Avatar
TcHunter
TcHunter is offline
What is the advantage of setting the throttle progressivity to moderate? Does it shorten up the twist? or just shoots more gas in? What I should ask is what does changing the TP actually do? I know they also have the normal or aggressive setting. Thanks in advanced I will be installing mine in couple of days, I am just trying to find all info I can.
Old 07-31-2014, 07:59 AM
barrygreen's Avatar
barrygreen
In a nut shell... the throttle response is quicker. If you open the app and look at the FAQ at the bottom it explains everything.
Attached Thumbnails Fp3 installed today-image-1784316655.jpg   Fp3 installed today-image-1706552452.jpg
Old 07-31-2014, 10:09 AM
Webo's Avatar
Webo
Webo is offline
The FP3 keeps impressing me every time someone with it post! I really like the user friendly interface and the features they put in this product. Kinda got me wanting to switch from my SEPST to the FP3! I would have went with this product if it was available when I did my stage one. Sounds like it's working great for you!
Old 07-31-2014, 10:29 AM
2014streetglide's Avatar
2014streetglide
2014streetglide is offline
The dongle does not stay on the bike, correct?
Old 07-31-2014, 10:44 AM
Kazz's Avatar
Kazz
Kazz is offline
Nope. Just flash your map and remove.
If you want to auto tune ,you leave it hooked up till you finish the tune. Also if you want to look at live data ( engine temp, rpm ) there are a few others I can't remember off hand.
I am very happy with it. The bike is running great.
Old 08-01-2014, 11:15 AM
Shepherdboy44
Vance & Hines website has a good video you can watch on how the throttle progressivity works and the different settings. Go to their website, scroll to the bottom and click on videos. They explain it real good. Hope this helps answer your question.
Quick Reply: Fp3 installed today
