14 FLHTK Break Squeak/squeal
I had the same problem at around 3000 or so. I pulled the pads and put Versa Chem Synthetic Caliper Crease & Brake Quiet on the back of them(no, I don't work for them. I just wanted to be specific). I used it on brakes when I was working on cars for a living. Anyway, it has taken care of the problem 100%. Since then, I have ridden in all kinds of conditions with no more squeaking.
I had same issue and work on cars for a living, and bikes on the side. All the replacement h-d brand pads come with a template and anti-seize for the back of the pads. I went a head and pulled the pads and put anti seize on the back of the pads (1/16" thick) where the pistons hit and noise is gone, pretty common for cars. Mike
Did the brake quiet work? I have a goose in the brakes on my 2015 FLHTK too. It's hard to tell when he's going to honk but when he does its loud!
[QUOTE=rmc115;13063379]I had same issue and work on cars for a living, and bikes on the side. All the replacement h-d brand pads come with a template and anti-seize for the back of the pads. I went a head and pulled the pads and put anti seize on the back of the pads (1/16" thick) where the pistons hit and noise is gone, pretty common for cars. Mike[/QUOTE
This worked for me as well, be squeak in over 8,000 miles since I did it on my '14 Limited.
