Shifter rattle on my Limited
Everything is tight. You can see the whole shifter assembly, front, rear, and shaft shaking and rattling. I am thinking I will take the whole thing apart this weekend and put some grease on the shifter shaft where it rides on the bushings and see if that takes care of it.
My 09 Ultra shifter started rattling a lot around 25k miles, I would stick my foot under it to stop the rattle. The shifter housing had excessive ware allowing the shifter shaft to rattle.
When I bought my 14 Limited I pulled the shifter shaft out and applied thick grease into the housing. I have 5500 mile on her and the shaft is still tight in the housing.
My plans is to grease the shaft at every 5k miles.
I found this shifter arm on J&P's. It has a grease fitting. http://www.jpcycles.com/product/540-0329
I'm thinking about installing it.
