2014-2023 Touring Models This Section Is For Rushmore/2014-2023 Touring Models
Electra Glo saddlebag lights
Old 09-01-2014, 01:28 AM
Freesince1903's Avatar
Freesince1903
Freesince1903 is offline
I only have one problem with mine. When I take my tour pak off my blinkers on dash blink fast but are blinking normal on the outside. When I plug the tour pak back in they work fine.
Old 09-01-2014, 10:19 AM
ACLazer's Avatar
ACLazer
ACLazer is offline
They are a great investment, this is in the run mode too.
I also added my Bright *** Light BAL1, off my 2012 trade, after this pic was taken.
Old 09-01-2014, 11:20 PM
twosailin's Avatar
twosailin
twosailin is offline
Mine do this also. I was wondering though, they are run, brake, turn. What I noticed is when turn signal is on and the brakes are applied, they quit flashing. The tour pack continues flashing though. Do they all do this?
Old 09-02-2014, 06:30 AM
bigdavem's Avatar
bigdavem
bigdavem is offline
6th Gear
You want more light,change the tail light for the LED. Really adds to the brightness. If they can't see all these lights, they are blind.
The only thing with this installation is I would like at least two more zip tie double sided tape mounts. I don't like the way the wire just droops down. I went to the dealer and several part stores but no one has them. Radio shack has white ones but they would look really bad. I will contact harley when they get in this morning.
Old 09-02-2014, 08:21 AM
New Adventures's Avatar
New Adventures
New Adventures is offline
Default Light disconnect
The plug is easy to disconnect, hopefully they left enough slack to hold the plug while depressing release and separating; Since i have the guards on around the bags, I place a cloth over the guard and disconnect the bag to lean out and then disconnect the plugs. Does 2 things protects the bag ojn and off as well as easy acess to plugs;
Old 09-03-2014, 11:13 AM
roadkinglobo's Avatar
roadkinglobo
roadkinglobo is offline
Have discussed this very same thing with the dealer and he checked the MOCO. They are aware of it and for now there is NO fix. Doesn't hurt anything in the dash!
By the way, I have a brand new IN THE BOX set of Electra Glo lights that are available if anyone wants to make a deal. I had put a set of these on prior to deciding to go with the tour pak detach kit (which includes a set). PM me or txt me @ 807-626-4789 $190. USD O.B.O. shipped to lower 48. I accept PayPal.
Mike (Lobo)
Old 06-07-2015, 08:07 PM
mrbreeze's Avatar
mrbreeze
mrbreeze is offline
3rd Gear
Anyone ever have to remove the Electro Glo led saddle bag lamps to send them back for warranty replacement! 3 of the led's flash when riding, not a connection problem with plug. Probably a bad solder joint on board. Just not sure of best way to remove 3M tape!
Old 06-08-2015, 03:50 PM
jbrooksca's Avatar
jbrooksca
jbrooksca is offline
Try trickling a little rubbing alcohol onto the top surface of the tape and paint and letting it soak in. It should soften the glue enough to allow a small gap to form at which point I would again apply a small amount of rubbing alcohol. You should be able to remove the lights, remove any remaining glue residue with a tissue soaked in rubbing alcohol. Follow up with a coat of wax.
Old 06-08-2015, 09:17 PM
472viper's Avatar
472viper
472viper is offline
I've removed a number of emblems that were on with 3M double side tape, I apply "GooGone" to the seam where the tape meets the applied to surface. I let the first application set over night. apply a second application in the morning then warm it up with a hair dryer. Pull from one end, you can drizzle more GooGone if need be and keep the hair dryer on it. They usually release pretty easy.
Old 06-08-2015, 10:38 PM
MikeyTX's Avatar
MikeyTX
MikeyTX is offline
Also, have some mono filament fishing line handy. It can be pulled along the underside of the tape in a sawing motion and it won't scratch the paint.
Quick Reply: Electra Glo saddlebag lights
