Weird problem with 6.5 infotainment using iPod
A few problems I'm noticing are when I start the bike, sometimes the iPod (Nano, iPhone and Classic iPod, I've tried them all) won't be recognized. It will show up, but the playlist/songs won't play until I shut the bike down and then start again. Also, when I create a single "Favorite" with the lower left push button below the "Home" button, it will retain the memory of that favorite until I shut down and restart. Then, the memory of the favorite button is gone. This is all intermittent. I've installed the new version and everything else is good. I've even tried 3 different iPod/USB cables so know it's not that. Any ideas or is anybody else experiencing this?
I'm getting the same issue. It will play and in the middle of a song it will cut off or start on another song. Today it wouldn't play at all, just showed the song on the screen. I guess I will have to try just a flash drive with the songs downloaded on it. Let me know if you find out what the fix is.
If you use a device like your iPhone or iPod you need to turn off the system first before you shut off your engine. Also, when you start your engine make sure its in neutral and wait till the "accept" message comes on. Then its time to "accept".
This may not work every time however you will find it works most of the time if you do this correctly in the right sequence. I had the same issues and I was told to do it this way and to my surprise I now have no issues. Even the advance skip tracks now works when before it stop working for me. There has been two times it did not work but I shut off my engine waiting two minutes and did everything in the correct sequence and it worked perfectly. Good luck.
I'm having the same problem with 4.3, which is even more pronounced when streaming music via Bluetooth from my iPhone 5. Also, the left toggle won't skip tracks during iPod playback. Very annoying, and it seems crazy that I would need to try another device to get music to play correctly. Worse, it's a distraction.
