FP3 and Autotune
I have a 2014 FLHTK with the Vance and Hines Powerduals and CFR slipons. After running through about two tanks of gas with my normal riding while using the autotune feature I flashed the results (attached?). Prior to the autotune the bike would start popping on decel around 1900rpm with the default mapping, otherwise ran strong. After the flash the loud popping at 1900rpm went away. I do have a little crackle at times when rolling off throttle, but it's not annoying to me. My question, how many cells have you populated (green) before flashing?
Edit:
Posted the wrong image
Edit:
I don't have the FP3 but with the SEPST I run auto tune and then update the map after each run. Then run auto tune again and update. This way you are tuning the tuned map so to speak. If it was me I would flash it to the map and then do another auto tune session and flash that data. Keep doing this until the amount of change on the cells is less than 5%.
I just flashed the ECM this evening after installing a high flow air filter kit and Rinehart slimline power duals and there 4" ovels. V&H recommendationed useing the map for there power duals and slash ovels. I only road about 15 miles this evening but no issues it runs good and strong throu all ranges, no popping or any noticeable problems.
Tomorow I am going to ride with the auto tune even thou I have no issues and continue flashing the maps until I can get an all green map.
Thanks for your advice, I may have just left it as it is.
I kept running the Auto Tune trying to get all cells green, After a while it wiped out all cells so I had to start over, this happened twice so I called V&H.
They said that you should only Auto Tune for no more then a tank of gas.
I think in your case I would apply the map and be done with it.
