Oil Archive (no new posts) An archive of oil related questions and comments.
Oil change before or after winter storage?
Old 10-07-2014, 09:46 AM
472viper's Avatar
472viper
472viper is offline
You could change it before AND after. Then you wouldn't be taking any chances.
Old 10-07-2014, 12:08 PM
Buckinfitch's Avatar
Buckinfitch
Buckinfitch is offline
Received 4,081 Likes on 1,514 Posts
some do exactly that... drain the old out/replace with cheap dollar store oil, drain and then put in the good stuff come riding season,
I actually did that.......... once.
Old 10-26-2014, 09:34 AM
ParkerH's Avatar
ParkerH
ParkerH is offline
Wow, I must walk on the wild side... When it gets to cold to ride or the snow flies I push the bike in the back of the garage and throw a cover over it. Maybe put some Sta-Bil in the gas tank. I don't go through a whole ritual of changing the oil before and after winter, firing it up every week, wrapping it in an electric blanket, praying to the H-D gods that it survives the winter... Every spring I turn the key, hit the starter button, and it pops off like it was just running the day before. I'll take it out for a ride, change all three oils, and ride it spring thru fall without an issue. Actually more like winter to winter. Runs and rides perfect. Don't loose any sleep over it, change it if you want, otherwise wait till spring.
Relax people, it's just a motorcycle!
StanC (10-15-2023)
Old 10-26-2014, 11:12 PM
user 8373900's Avatar
user 8373900
user 8373900 is offline
Originally Posted by gusotto
Have miles on the oil?
Change before winter storage, otherwise the parts just sit in a bath of contaminated oil(s).
Harley engines are dry sump.. The parts don't sit in oil.
Mark
The following 2 users liked this post by user 8373900:
bgdv1 (11-01-2019), Campy Roadie (10-17-2019)
Old 10-29-2014, 08:17 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
With over forty years of riding I've only ever changed oils at the due point of either mileage or time. I know there are different opinions, but the simplest thing to do is ignore them and change when it is convenient!
Old 10-16-2019, 10:15 PM
Thunder Road's Avatar
Thunder Road
Thunder Road is offline
Stage II
The Transmission and Primary sit in the old oil all Winter.
Old 10-17-2019, 07:08 AM
Screamin beagle's Avatar
Screamin beagle
Screamin beagle is offline
Received 3,991 Likes on 1,997 Posts
Oils cheap compared to engine parts. It's your bike do what you want with it. I have a rough idea how many miles I do in a season and plan my oil changes according to that, so that last end of season change is usually very close to needing to be done anyway. It's only oil...they make more every day
DD Dont
2014+ Touring Models
10-29-2014 01:42 PM
smokinfromshootin
10-14-2012 01:56 PM
99superglide
11-15-2011 02:19 PM
Scotchdrinker
09-11-2008 05:42 PM
ButtMan1000
11-05-2007 06:05 AM
Quick Reply: Oil change before or after winter storage?
