clogged oil filter
clogged oil filter
09 Road Glide less than 20,000 miles -- brass shavings in oil --- that can be explained by cam bearings--- also oil filter with thick gray gooie substance that looks like case sealant --- rolled up enough to form a ball the size of large grape --- never lost oil pressure, but also found cracked oil pump. Any similar problems ?? Worried if there is more sealent inside engine cases.
Sure it was case sealant and not metal flake sludge from disintegrated bearings, thus taking out the oil pump?
