hello new to the forum, evo oil pump drive shaft
hello i need to replace the oil pump drive shaft on my 97 evo 1340.
is there anyway the shaft can be removed replaced with the engine in situ.
many thanks in advance.
ps it is a road king
Hi Paul and welcome to HDF. Which Spilsby are you in?!
Your question begs others, but I suspect at the least you will need to remove the oil pump to get at the drive shaft. You'll get great advice over in the Evo section, where our Evo experts reside, so I suggest you pop over there.
cutlass1972
Exhaust System Topics
08-08-2011 03:42 PM
