Oil Archive (no new posts) An archive of oil related questions and comments.
Water in chaincase oil.
Old 08-30-2015, 02:19 AM
Rafael Escalera's Avatar
Rafael Escalera
Rafael Escalera is offline
Stage II
Default Water in chaincase oil.
I have a 2015 Harley Road King and after 2000 miles, when I changed the oil in the chaincase it was grey and cloudy, which I assume is due to water in the oil. Now for the last two weeks it has been raining severely here in Hawaii and I ride my bike in the rain, even in very heavy rain. Is this what is causing the water in the chaincase oil?
I changed it because in first gear the clutch started releasing in a jerking way right at the end of the clutch travel and the dealer said that is a sign of moisture in the oil.
Old 08-30-2015, 07:35 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,466 Likes on 4,598 Posts
You shouldn`t have to change primary oil at 2,000 miles, even if you ride in a hurricane every day, water should not be able to get into the primary area.
What does the transmission lube look like, is it normal?
Old 08-30-2015, 12:31 PM
nevil's Avatar
nevil
nevil is offline
If oil's not leaking out of the primary from one of the seals or the gasket I can't see how water could get in. Unless it was there when you got the bike.
It's under warranty, I would get the dealer to check it out.
Old 08-30-2015, 06:14 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,810 Likes on 1,063 Posts
I don't think that you're riding the bike far enough or long enough to get it good and hot, up to operating temperature. That's causing condensation in the motors components. It'll take a good 30-45 minute ride or more depending on where your riding at to heat her up to the proper temperatures.
Old 08-30-2015, 07:11 PM
Rafael Escalera
Stage II
Today I changed oil and transmission and they looked ok. I'm taking it to the dealer to have it looked at when I take it for the saddle bags recall. I don't think it matters but I can be stuck in stop and go traffic for 40 minutes at a time using the clutch in the friction zone.
prestob
06-04-2018 10:09 AM
masterblaster
06-27-2012 12:00 PM
cdesero
07-04-2011 01:58 PM
stubby
08-14-2006 12:54 PM
stubby
08-14-2006 12:54 PM
Quick Reply: Water in chaincase oil.
