Oil Archive (no new posts) An archive of oil related questions and comments.
Oil pressure relief valve sticking
Old 09-22-2015, 03:00 AM
Biker Boy 53's Avatar
Biker Boy 53
Biker Boy 53 is offline
6th Gear
Default Oil pressure relief valve sticking
My cam bearings in my 01 flhrci went bad and came apart, drove it almost a month while it was going bad. Installed S&S gear driven 510 cams lifters and billet oil pump, new valve seats and guides.
Within 60 miles oil pressure light came on and no oil pressure. My mechanic says the relief valve is sticking and thinks the cam support plate is warped and needs to be replaced. As of this posting I'm not sure if he replaced the valve parts or not, can this plate warp?
From what I've read in here the plate could be cracked or the valve could just need replacing. I don't want to just replace valve and put it back together and still have a problem.
Thanks for any info.
cthagreekgod
Engine Mechanical Topics
07-02-2019 07:45 AM
ralix13
01-26-2015 10:14 AM
John Mcintosh
Exhaust System Topics
08-25-2010 02:20 PM
Mackatoni
11-15-2008 12:33 AM
tgarrett1
09-02-2008 03:08 PM
Quick Reply: Oil pressure relief valve sticking
