Oil Archive (no new posts) An archive of oil related questions and comments.
Removing a wrong hex nut for oil drain (Engine Oil Change)
Old 10-09-2015, 03:44 PM
Erni's Avatar
Erni
Erni is offline
Stage III
Default Removing a wrong hex nut for oil drain (Engine Oil Change)
Hello,
I have accidentally removed the Alan-Hex nut instead of the oil drain nut on my Electric Glide when try to change the engine oil myself for the first time.
The Alan-Hex nut is next to the oil drain nut (5/8"), which is according to the manual the Alan-Hex should not be removed (DO NOT REMOVED as stated in the manual).
Most likely half of the oil has been drained from the engine thru it until I realized that it is the wrong nut that I removed.
Any advise what could I do in this case?
Should I continue draining the oil thru the correct nut, and put back the Alan-HEX nut properly and continue the engine oil (and filter) change?
Or, is there any other concern that I need to be aware of?
Erni
Old 10-09-2015, 04:00 PM
rhythm1978's Avatar
rhythm1978
rhythm1978 is offline
I am not certain, but I think it is the nut to check for wet sumping on some models. I could be wrong. They say not to remove it. But I don't see any reason you couldn't red Loctite it back in once it is empty. Hopefully someone else has more info.
Old 10-09-2015, 04:12 PM
Erni's Avatar
Erni
Erni is offline
Stage III
Thanks Michael,
Just want to make sure that I will not miss any other section of the engine that may need oil refill (which drained thru this hex nut). Also, how to properly tight the hex nut back, I saw a special (red grease/glue) was applied in the nut.
Old 10-09-2015, 04:45 PM
jmn1960's Avatar
jmn1960
jmn1960 is offline
that is a tapered pipe thread ,, just loc-tite it and put it snug,, don't overtightin it or you could spilt the hole it goes into,,go ahead and continue with the oil change wont hurt any thing,, that is the same hole I used to put my oil temp gauge sender ,,just SNUG IT and you'll be fine
mike
Old 10-09-2015, 04:47 PM
rhythm1978's Avatar
rhythm1978
mike
I have read about it in reference to people installing an oil temp gauge. My bike doesn't have that plug, but it sounded a lot like what I had read.
Originally Posted by Erni
Thanks Michael,
That red "grease/ glue" you see is most likely red Loc-Tite on the threads.
Old 10-09-2015, 04:49 PM
rhythm1978's Avatar
rhythm1978
*deleted
Old 10-09-2015, 05:06 PM
xcbullet's Avatar
xcbullet
xcbullet is offline
Saprised it came out I had to heat mine up to get it out, to flush case after cam bearing failure.
Old 10-09-2015, 05:31 PM
Erni's Avatar
Erni
Erni is offline
Stage III
Mike and Michael, thanks!
tnichols
17
05-31-2018 08:18 AM
Mogar
03-18-2011 09:33 PM
tjae
VRSC Models
10-06-2008 03:39 AM
glebo
10-09-2006 04:00 PM
Patch
08-01-2006 02:02 AM
Quick Reply: Removing a wrong hex nut for oil drain (Engine Oil Change)
