Possible change to synthetic oil question..
I recently purchased a 2010 Fat Boy Lo with 13,xxx miles. Since I have no idea of the oil change history, I am getting the oil, transmission and clutch oil all changed this week. My question is this. If I don't know the kind of oil this bike has been using, can I safely change to Amsol synthetic without any issues? Or should I just use regular oil and not take the chances?
Ok... why would you think putting syn in wouldn't be safe? Just curious.
To answer your question, use any brand syn you like. If you want to pay for Amsoil that's cool. That engine, tranny, and primary won't know the difference between Amsoil, Valvoline, Mobil, Lucas, etc. Just don't use anything with friction modifiers in the primary because of the clutch.
I was told that if your not sure what kind of oil has been used in it previously and the bike has over 10k miles on it. do not use synthetic. I will just go with what the mechanic recommends. Thanks for the comments.
Wow! I would wonder about that mechanic! That engine is just barely broken in at 13,000 miles. Get true synthetic in there asap! Unless of course you're the type that puts 10 or 20K on a bike and then moves on to another. In that case longevity of the engine is of no concern and the only benefit of the more expensive synthetics would be slightly cooler engine temps.
If your going with what your mechanic reccomends why did you even bother starting this tread. Use any oil you like, as long as its changed at a proper interval any of them will be fine
Received 1,934 Likes
Now for anyone reading this thread who is actually looking for a bit of info regarding oil. Check out other threads on the "Oil" section of this forum or go to "Bob The Oil Guy's" site, or,,, just look elsewhere,,,anywhere,,, cause jkiser's mechanic is wrong.
Must have missed it.
