Mobil v-twin 20-50 for everything??
And it's available everywhere too.
They included Spectro with my DD6!
Because HD can't seem to make up it's mind. For decades they recommended gear oil for the tranny, 80W-90, with a recommended 5,000 mile service interval.
Then mysteriously the first "Anniversary 15th" FatBoys showed up in the '05 model year with Syn 3 in all three holes. (Remember when MoCo warned us about the evils of synthetic oil in a Harley motor back in the 90's?)
Then in '06 with the advent of the 6 speed Dyna (Guinea Pig,) the extended the service interval change to 20,000 miles.
Now they are going back to gear oil!
I trust Baker and other professionals with a vested interest in their product's longevity 10 times over any recommendation from Harley. (It's "normal"... )
The recommended tranny lube is gear oil (once again.)
The above is your safest choices and motor oil is the #! choice of Mobile, Amsoil and Harley as well as Harleys Formula+ for the HD transmission and primary.
Gear Lube is a second choice and many have good luck with it, keeping in mind gear lube is/was intended as differential lube not transmission oil. Some high pressure additives of gear lube, depending on the company are not the best choice for seals and corrosion of soft metal for this reason I do not use it as there, for me personally, is no benefit.
