Oil Archive (no new posts) An archive of oil related questions and comments.
Draining oil cooler when changing oil
Old 01-03-2016, 02:37 PM
Dudlee's Avatar
Dudlee
Dudlee is offline
Default Draining oil cooler when changing oil
Was wondering if its worth removing the cooler and lines to drain them when I change the oil.. Don't think there would be more than 1/3 or 1/2 cup there..
Old 01-03-2016, 02:50 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,532 Likes on 3,784 Posts
There is quite a bit of stained oil in many places in a Harley motor. They run with close to 20 ozs. in the sump. What lubricates the inner cam bearings. It's all filtered. No big deal. Just replace it to the owners manual recommendation and you will be more then safe. I base this on 50 years of working on motors.
Old 01-03-2016, 10:01 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Only if you're completely **** about your bike! LOL There's not enough there to make any difference one way or another.
Old 01-04-2016, 08:18 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
The only bike I have ever owned with an oil cooler was a new BSA Rocket 3 and, yes, I disconnected and drained the cooler. As when changing the oil filter, you should run the bike long enough for the oil level to steady, then top up if necessary, to compensate for the oil that has refilled the filter and cooler.
Old 04-03-2016, 12:31 AM
BrownSanta's Avatar
BrownSanta
BrownSanta is offline
I use the Scavenger to do a complete oil change on my bike
http://roguechopper.com/
Old 04-03-2016, 04:35 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Aw sh*t!!!!!!
You DIDN'T just bring up the sc*venger did you!!!
8 pages at least before we go to thread lock.
big cahuna
04-28-2014 11:58 AM
sportyfan
01-25-2013 05:00 PM
dan conner
06-27-2010 05:24 PM
leeinmemphis
08-24-2009 10:04 PM
fiddledicksr
Exhaust System Topics
11-27-2005 05:18 AM
Quick Reply: Draining oil cooler when changing oil
