Oil Archive (no new posts) An archive of oil related questions and comments.
Redline 5w50 Early Results...It works!
Old 01-10-2016, 03:59 PM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
Default Redline 5w50 Early Results...It works!
Ran the Redline 5w50 for about 700 miles, and 10 months. I had the oil analyzed and there were some good and bad. I like the cold startup characteristics of this oil as there was way less chatter, was very easy to start and the oil circulated twice as fast as the 20w50. When fully warm the engine sounded great and temps were about the same. It did shear a bit but no where near what I was expecting, seem to hold up really well. I did not notice any increase in fuel mileage or a huge reduction of wear metals as I expected, I created a ratio formula to compare both oil runs to get this information. There was some fuel contamination and high silicone that I was disappointed about but these may be another issue. However, the question for me has been answered and that is that it is perfectly ok to run 5w50 with the right setup in a 96 c.u. in HD.
File Type: pdf
Old 01-10-2016, 04:10 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Received 5,378 Likes on 2,626 Posts
Good lord, would you oil weenies please post your obsessive threads in the oil forum?
WTF?
https://www.hdforums.com/forum/oil-a...ted-topics-30/
Old 01-10-2016, 04:16 PM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
WTF?
Naw, here is good.
Old 01-10-2016, 04:19 PM
sgs14cp's Avatar
sgs14cp
sgs14cp is offline
Did you mean 7000 miles and not 700?
Old 01-10-2016, 04:25 PM
fireaxxe's Avatar
fireaxxe
fireaxxe is offline
No only 700 miles, didn't get to ride much last year but wanted to see how this oil was trending.
Old 01-10-2016, 04:34 PM
nocarb's Avatar
nocarb
nocarb is offline
I don't know what you were running on your last UOA but I would put it back in. Wear numbers are higher. Look at aluminum 2 ppm @ 700 miles and 3 ppm @ 3900 miles. Copper 6 ppm @ 700 miles and 16 ppm @ 3900 miles. Lets say you ran this oil to 4200 miles.(just for simplicity) Copper may be @ 42 ppm and aluminum @ 14 ppm.
May also want to look into the fuel dilution.
Old 01-10-2016, 04:44 PM
Keithhu's Avatar
Keithhu
Keithhu is offline
Naw, here is good.
Yeah, because we've never heard of your magic elixir.
Old 01-10-2016, 04:55 PM
Hausguy's Avatar
Hausguy
Hausguy is offline
How can you tell anything with 700 miles...
Old 01-10-2016, 05:14 PM
mikeo33y's Avatar
mikeo33y
mikeo33y is offline
what he said. are you serious. 700 miles. that oil isnt even warm. im kindve shocked you actually posted this. not because its about oil but because the oil is barely used.
Old 01-10-2016, 05:19 PM
bdtaylor1979's Avatar
bdtaylor1979
bdtaylor1979 is offline
My thoughts as well.
Quick Reply: Redline 5w50 Early Results...It works!
