Oil Basics, Part 2
#62
And you can get 99% of the benefits of a synthetic by using only 25% of the volume of it, mixed with dino oil. It is absolutely true that "synthetic" doesn't mean "better". There are good and bad in both varieties, so knowing what attributes to look for in an oil or grease, and understanding what you might be doing that's beyond the bike manufacturer's intended application is key to making the right choice of lubricants.
#63
I'm probably just being dumb here, but can i use an oil additive in synthetic oil
ive seen this stuff and it says you can add it to synthetic
www.everglideoil.com/everglide-synthetic
but has anyone ever done this type of thing before
cheers
Mal
cheers
Mal
#64
Mal, every oil we can buy is stuffed full of additives. While any given bottle we pick up contains 'oil', a fair proportion is a cocktail of additives, which each brand will make up to its own secret recipe. If you use a well-known brand of oil, recommended for your bike, then use it as it comes. I really don't believe there is anything to be gained by adding yet more 'stuff' to it!
The following 2 users liked this post by grbrown:
motorcyclemal (03-24-2017),
smitty901 (03-24-2017)
#65
cheers
Mal
cheers
Mal
#66
Hiya mate thanks for the info- i moved to Greece recently and the summers here are harsh- someone over here told me they used an additive and i thought that made sense- Their are no HD dealers here and people tend to do anything to keep things going.
Mal
Mal
#67
You cant always get the good stuff over here, i think thats why people use additives-
#68
#69
H-D does have a Greek website, the only problem is it's all in Greek! I can't make out if there are dealers over there, but if you don't read Greek perhaps a local friend can guide you through it. It's not beyond the wit of man to buy in oils, or cross an International border for some, depending on where you're located?
#70
If that is so then definitely don't do what they do! Shovels and older vehicles, of all brands, were built to very different standards than modern vehicles like your bike, are probably also well worn by now. If you have the owners manual for your bike you will see that when Harley oils are not available you should use oils for diesel engines. Use that as your guide. If you don't have a manual, you can download one from the US H-D website, just go to the Owners tab.
