Transmission Oil Plug
RE: Transmission Oil Plug
The transmission oil drain plug on your fatboy is up between the shock's and hard to get at....it's a gift from harley to make you work if you want to change your own oil [:@]. The motor oil drain plug is right under the oil bag down under the swing arm closer to the back wheel on the right side and the primary is just under the derby cover if you need to know. The transmission plug is tricky so be careful you don't strip it or cross thread it. Good Luck.
The tranny drain plug has wrenching flats on it, but is also an internal-wrenching bolt as well. If you use an allen-head driver bit (I believe it's a 1/4" bit) with a ratchet and a 1/4" drive extension, it's simple to remove & replace the plug.
Allot easier to get to the tranny bolt if you have a bike jack.....easier to see
where you are putting the bolt instead of doing it 'blind'.
Getting it out is easy, it's just getting it back in that takes fantastic four type long strectchy skinny fingers...
ORIGINAL: anubisss
