Oil Archive (no new posts) An archive of oil related questions and comments.
79 sportster oil pressure
Old 04-19-2008, 05:10 PM
jba66ihc's Avatar
jba66ihc
jba66ihc is offline
Stage IV
Default 79 sportster oil pressure
Hi Im new here my name is Jon.I recently purchased a 1979 Sportser.It had a few minor issues I streightend them out and got it running.It has sata while inside has 13,000 miles.It was last rode 7 months or so ago.It started right up ran great but it had wireing issues with the starter relay.Anyway I got it worked out and started it again today and noticed the oil light on and the lifters ticking.I shut it off imediatly pulled the oil filter and there is metal in the filter.Is there a common problem with oil pumps on these 1000cc engines? I posted this in the sportster section also.
Old 04-19-2008, 07:58 PM
jba66ihc's Avatar
jba66ihc
jba66ihc is offline
Stage IV
Default RE: 79 sportster oil pressure
I pulled the side cover off.The oil pump gear is gone.I cought it at a good time.It only ran a couple seconds.If I was rideing down the road it would meant a engine now is just a oil pump.
Old 04-19-2008, 08:03 PM
streeteagle's Avatar
streeteagle
streeteagle is offline
Did you check your oil level? Light flickering & valves ticking means low oil pressure. In any event, I would change the oil & filter. If it still does it you may have a bad pump or a plugged oil line. Also, may want to invest in an oil pressure unit.
Old 04-19-2008, 08:05 PM
streeteagle
ORIGINAL: jba66ihc
Disregard last post-was writing it before I saw you found the problem.
DavidStiebel
12-13-2015 10:07 AM
dave pfingstler
08-22-2015 10:41 AM
jba66ihc
04-19-2008 07:56 PM
sphinx
20
08-19-2007 06:58 AM
rammboo
07-11-2005 02:52 PM
Quick Reply: 79 sportster oil pressure
