Oil Archive (no new posts) An archive of oil related questions and comments.
60 weight oil in twincam 88 non modified?
Old 07-08-2008, 09:31 PM
cromagnon's Avatar
cromagnon
cromagnon is offline
Default 60 weight oil in twincam 88 non modified?
Had my 10K service done on my 05 88 Twin Cam by a non dealer Harley servicer.
&nbsp\\;
They replaced my oil with AMSOIL 60 WT Heavy Racing Oil.
&nbsp\\;
It seems to vibrate a little more before and the engine does not sound the same.
&nbsp\\;
Does anyone know if this will be a problem.&nbsp\\; I told them to change to AMSOIL synthetic but was under the impression that they would use standard weight 20-50.&nbsp\\; They told me when I came in to pick it up that 60 weight is better in hot weather like over 80 degrees.&nbsp\\; It's not over 80 all the time at least not in the morning.
&nbsp\\;
Does anyone have an opinion or know of any potential problems?
Old 07-09-2008, 12:47 AM
bear95252's Avatar
bear95252
bear95252 is offline
Default RE: 60 weight oil in twincam 88 non modified?
No Problems. 60 wt is normally used in Knuckle heads and Shovel Heads. 20W50 is the usual oil for twin cams. AMSOIL says you can use the 60 wt where it is recommended or desired. It is also wet clutch compatible. So ride it like you stole it and enjoy.
Bear
AMSOIL Premier Direct Jobber
Old 07-09-2008, 09:19 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
I would only use a 60w oil if you live in the South East or Southwest US where it is warm all the time. If you do run that oil when it's below 70 degrees let the bike idle for at least&nbsp\\;3-4 minutes before you drive off when cold starting.
Old 12-11-2014, 08:44 PM
racer11's Avatar
racer11
racer11 is offline
If you want 60wt,,,go to the redline web site they have a 20-60 combo.
hddave2
783
02-16-2020 12:37 PM
deleontow
15
07-10-2008 05:04 AM
hollerback
06-24-2008 12:32 AM
Mark g
06-11-2008 11:22 AM
Jimbo59
06-09-2008 06:03 AM
Quick Reply: 60 weight oil in twincam 88 non modified?
