Oil Archive (no new posts) An archive of oil related questions and comments.
Synthetic Oil for 'Fatboy?
Old 03-19-2006, 10:43 PM
SDozier's Avatar
SDozier
SDozier is offline
Default Synthetic Oil for 'Fatboy?
I recently had a new cam, cam bearing, etc. put on my bike due to a cam bearing and other problems. The Fatboy has 500 miles on it since the rebuild and needs an oil change. The wrench stated he uses only Castrol 20w-50 (automobile oil) in his bike because Harley recommended older EVO's to run on motorcycle oil but not synthetic. Can anyone share experiences they have had with running Synthetics in a mid-90's Fatboy?
'54
Old 03-19-2006, 10:57 PM
pococj's Avatar
pococj
pococj is offline
Received 1,211 Likes on 461 Posts
Default RE: Synthetic Oil for 'Fatboy?
ORIGINAL: SDozier
'54
I run synthetic in my '87 Evo Sloptail. It ain't a problem. HD didn't recommend synthetic because they didn't have their own over-priced synthetic. They might still not recommend it, but only because they haven't tested it in Evos.
Use it. Stands up better to heat, and maintains its viscosity longer. That 20w-50 Castrol car oil is probably 10w-30 after 1000 miles.
Old 03-20-2006, 05:54 AM
wlbowers's Avatar
wlbowers
wlbowers is offline
Dang I run mobile one in my lawnmower. I buy it by the case.
Old 03-20-2006, 08:52 AM
websterdan's Avatar
websterdan
websterdan is offline
I run Mobil 1 in all my stuff (including the lawn mower, also). I've used Mobil 1 in all my bikes. My Buell used less oil and had less oil coming out of the vents (air cleaner).
Old 03-20-2006, 09:21 AM
fl_799's Avatar
fl_799
fl_799 is offline
Castrol 20w-50 is probably the best conventional but I'd go with the Mobile one!
Old 03-20-2006, 08:38 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Use the synthetic.......you won't be sorry
Old 03-20-2006, 10:39 PM
SDozier's Avatar
SDozier
SDozier is offline
Sounds convincing. I will put Mobil 1 in this weekend. Appreciate the input.
SD
jcimaglio
05-10-2018 07:26 PM
larry bart
07-12-2011 07:58 PM
TopZR
21
03-26-2009 10:22 PM
robopine
12-17-2007 11:32 AM
eagle56
11-11-2007 06:03 PM
Quick Reply: Synthetic Oil for 'Fatboy?
