Oil Archive (no new posts) An archive of oil related questions and comments.
Lucas synthetic oil stabilizer
Old 02-10-2009, 02:06 PM
skidder's Avatar
skidder
skidder is offline
Default Lucas synthetic oil stabilizer
Will a product such as Lucas oil stabilizer make an oil such as H-D Syn 3 better? H-D oils have a reputation as not being the best stuff, good not great.So would adding a stabilizer improve it any. Would it improve even say Amsoil synthetic? I,ve also read that this stuff gets rid of that sewing machine sound that some H-D bikes make. Thanks for any input.
Old 02-10-2009, 03:52 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Lucas oil stabilizer is just a thicker oil with a very weak additive package. It will quiet your engine because it is thicker...but a straight 50 or 60w oil will do the same thing without diluting the additives in your oil. Lots of guys use it but I wouldn't. Lucas will not make any oil better. You will get less mechanical noise with a mineral base oil like HD360 than you will with synthetics. But the usual Harley mechanical noise is no indication of wear in your engine.
I would substitute a quart of HD360 50w for the lucas and see what happens or go to a 20w60. But with a thicker oil in cold temps you are going to get more cold start wear on your engine.
Old 02-10-2009, 05:03 PM
garyhendley's Avatar
garyhendley
garyhendley is offline
no additive will help that cheap harley syn 3
really the harley syn 3 is crap made by citgo its only a blend and a bad one at that
try amsoil 20/50 in the motor and primary and 75/90 sevear gear in the tranny
nice smooth shifting and runs cooler-ride safe
Old 02-10-2009, 05:05 PM
rbabos's Avatar
rbabos
rbabos is offline
+1. Viscosity is the answer, not additives.
Ron
Old 02-11-2009, 06:44 AM
dynarule's Avatar
dynarule
dynarule is offline
Just take your windsheild off and you wont hear it any more! LOL.
OddJack
07-29-2014 11:17 PM
SweedTownHD
02-15-2012 03:48 PM
DarthMaul
09-04-2011 07:50 AM
GA1dad
03-13-2009 04:13 PM
Fastlane
08-24-2007 11:35 PM
Quick Reply: Lucas synthetic oil stabilizer
