Oil Archive (no new posts) An archive of oil related questions and comments.
Fork Oil Capacities All Years and Models
Old 07-28-2013, 06:17 AM
smitty901's Avatar
smitty901
smitty901 is offline
Received 9,561 Likes on 5,153 Posts
Better check those weights of lube again your a bit high
good luck with 30 weight in a front fork. even 20 is pushing it.
Old 04-30-2014, 12:43 PM
Screamin Willie's Avatar
Screamin Willie
Screamin Willie is offline
Originally Posted by skycrane
I searched the internet for this info and found there wasn't anything out there. Most of us don't have a harley manual anymore!
"Dry fork requires .5 to 1.0oz more than the wet amount due to residual oil left clinging inside the fork." Use 20 weight for average conditions. For extreme conditions use 10 weight or 30 weight accordingly."
-WET: Means you just drained the oil out of the plug and want to refill it.
-DRY: Means you dissassembled the forks and cleaned them dry inside/out.
WET.....DRY...(oz)............MODEL/YEAR.........................................
5.5 ..... 6.5 ...... Sportster thru 1972
5.0 ..... 6.0 ..... Sportster 1972-83
5.4 ..... 6.5 ..... Sportster 1984-87
9.0 ..... 10.2 ..... Sportster 1988-2003
10.5 .... 11.6 ..... Sportster 2004-08
9.0 ..... 10.2 ..... XL 883 Hugger thru 1991
10.7 ..... 12.1 ..... XL Hugger 1992-99
6.5 ..... 7.0 ..... FL/FLH 1948-E77
7.75 ..... 8.5 ..... FL/FLH L1977-84
7.75 ...... 8.5 ..... FLT 1980-97
8.7 ..... 9.7 ..... FLT 1998-2001
10.1 ..... 11.1 ...... FLHR 2002-09
5.5 ..... 6.5 ..... FX/FXE 1972
5.0 ..... 6.0 ..... FX/FXE 1973-83
6.0 ..... 7.0 ..... FXR/FXRS 1985-86
9.0 ..... 10.2 ..... FXR/FXRS 1991-94
9.2 ..... 10.2 ..... Dyna/Low Rider 1991-2005
10.2 ..... 11.2 ..... Dyna Wide Glide 1991-2005
9.0 ..... 10.2 ..... FXWG/FXST 1980-84
10.2 ..... 11.2 ..... FXWG/FXST 1985-2006
11.5 ..... 12.5 ..... FLST 1986-2006
12.4 ..... 13.4 ..... FLST 2007-09
11.5 ..... 12.5 ..... FXST 2007-09
10.5 ..... 11.6 ..... FXSTD 2007
Well I hope this helps atleast one person out. Cheers.
Great info, thanks.
Willie
Old 06-01-2014, 10:45 AM
lowflyer's Avatar
lowflyer
lowflyer is offline
Originally Posted by silvernblack
Thanx, yall are better than my local Harley dealer. They wouldn't help me because they wer too busy and they get paid by the hour. There words exactly. Legacy Harley Davidson in Odessa tx.
That`s not right. Bring it to the attention of the owner if you think it might do some good.
Old 05-04-2015, 11:27 AM
solofatty's Avatar
solofatty
solofatty is offline
Stage I
Are these measurements per fork or combined??
Old 05-06-2016, 12:07 PM
Crow Null's Avatar
Crow Null
Crow Null is offline
Stage I
I'm running 10 over 41mm tubes. Does that make any difference in the amounts that you have listed?? Thanks
Crowrebel@juno.com
Old 12-09-2016, 08:56 AM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is online now
Received 4,792 Likes on 3,303 Posts
It did, Thanx Man
Merry Christmas
Old 01-20-2017, 11:59 PM
eazyride's Avatar
eazyride
eazyride is offline
Those measurments are for both forks rite?
Do u have one for fxdx?
Or is it the same with dyna/low rider?
Old 01-21-2017, 05:19 AM
98hotrodfatboy
No ounces per tube...
Old 02-02-2017, 04:13 PM
Erik Lundberg's Avatar
Erik Lundberg
Erik Lundberg is offline
Anyone use Red Line Suspension Fluid?
https://www.redlineoil.com/product.aspx?pid=29&pcid=18
"Used in many Harley-Davidson® and American V-Twin motorcycle forks and rear shocks that have not been revalved"
Old 11-21-2017, 02:41 PM
ThrasherBiker's Avatar
ThrasherBiker
ThrasherBiker is offline
Stage I
Does anyone know the qty of fluid for 2016 FXDL (dyna low rider). It has 49mm forks at stock length.
Quick Reply: Fork Oil Capacities All Years and Models
