Spectro Oil -
Spectro Oil -
On another forum they recommend the spectro so I went searching for it and I went to the only place I could find within a 20 mile radius the other evening and I about fell over - No kidding this is what they quoted me - BTW it was a Yamaha shop who would have to order the Primary and trans oil.
Platinum 20w50 $15 @ quart ( 4 quarts)
HD Primary Chain $9 @ quart (2 quarts)
HD platinum 6 spd trans oil 75-140 $22 @ quart (1 quart)
And There is a shipping charge of $15
So when I add in a HD filter and washers @ $16 , to change all my fluids it will cost me $137 (with tax and S&H) WOW! And I am picking up the oil at the shop, turning my own wrenches and disposing the old oil. I think that is a little much to change oil when there are other options -
A few Questions -
1. How does Spectro Compare in performance with Amsoil?
a) Engine 20W-50
b) Transmission 75W-140
c) Spectro has a specific primary oil - does Amsoil?
2. How does Spectro compare in price with Amsoil?
3. What is the difference btwn Amsoil and Spectro that would warrant the cost?
Thanks
Russ
A few Questions -
a) Engine 20W-50
Thanks
Russ
Whew, those items are just a little pricey for my pocket book. Stick with what works and shun the snake oil, it'll save you a ton of money and a whole lotta grief.
Bart
Bart
A few Questions -
a) Engine 20W-50
Thanks
Russ
M1Vtwin 20w50 engine
M1 75w140 gear oil -trans
M1 Vtwin 10w40 primary
Same with amsoil.
There is virtually very little difference in all of these oils.
If you want a good dino oil try www.bradpennracing.com
I just switched to Amsoil, mainly becuasde it is easy to find, local Fleet Farm has it $10.95qt and I use a WIX filter from O Reilys $4.75. When I drop primary and trans I'll be using Amsoil or Redline if I can find it local.
I had planned on using Mobil1 but cannot find 20-50 for Vtwin so went to Amsoil instead.
mps
mps
Anyone use http://www.schaefferoil.com/705_racing_oil.html . A local swears by it. NAPA sells it. Not very pricey. Mostlikedly cause they don't advertise like the big corparations .
Thanks - A buddy of mine said to stick with the HD primary - that there is nothing wrong with that in the primary- it is just the transmission and the engine that I really need to worry about. Thoughts?
