Oil Archive (no new posts) An archive of oil related questions and comments.
What weight is HD primary fluid???
Old 05-17-2010, 10:21 PM
Bluegrasser's Avatar
Bluegrasser
Bluegrasser is offline
My primary currently has Formula+ in it, but it's about to get a dose of conventional Rotella T 15W40 which is JASO-MA certified. I figure it's great (dare I say legendary) oil that is about half the price of Formula+. That said, I have no problems with Formula+ and would run it again.
Old 05-18-2010, 12:17 AM
bikerlaw's Avatar
bikerlaw
bikerlaw is offline
HTML Code:
Yes, it is a simple SAE50 GL-1 conventional oil (made by Citgo).
Humm, I didn't know it was a Citgo product. Kinda funny, not much would make me switch to another alternative....but hugo chavez and his anti american BS just might be enough.
Old 05-18-2010, 01:08 AM
Potato_Potato's Avatar
Potato_Potato
Potato_Potato is offline
Originally Posted by bikerlaw
HTML Code:
Thats just one of the reasons I don't buy any of the petroleum products from HD - The other is that there are much higher quality products available.
Old 05-18-2010, 07:36 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Originally Posted by Lost1
I saw an analysis on it once and it's a straight 50W mineral oil.
+1 50w with weak additives. A real money maker for the moco.
Old 05-18-2010, 07:55 AM
AddictedUSAF's Avatar
AddictedUSAF
AddictedUSAF is offline
So from experience what is the best to put in the primary that will not mess with the clutch plates? B/c I have amsoil 20W-50 in the motor and sever gear 75W-140 in the trans. Is the trans. weight good or should I move down to the 90? Thanks
Old 05-18-2010, 08:37 AM
Bluegrasser
Originally Posted by AddictedUSAF
So from experience what is the best to put in the primary that will not mesh with the clutch plates? B/c I have amsoil 20W-50 in the motor and sever gear 75W-140 in the trans. Is the trans. weight good or should I move down to the 90? Thanks
If you want to stick with Amsoil you could use 10W40 MC oil.
Old 05-18-2010, 08:51 AM
AddictedUSAF
In the primary?
Old 05-18-2010, 09:01 AM
Route66rider's Avatar
Route66rider
Route66rider is offline
Well, that fact surely eliminates the use of HD oil for me.
Old 05-18-2010, 09:08 AM
Lost1's Avatar
Lost1
Lost1 is offline
Trans oil is fine- any gear oil will suffice. Harley spec's Syn 3 20W-50 or Formula+ with 20k mile OCI, so obviously it's not an overly hostile environment. Even el-cheapo gear oils are designed to be put in heavy truck differentials & run for 50k miles plus, so our little gearboxes won't put a hurtin' on any decent gear lube.
Primary is good with Formula+, ATF, Rotella 15W-40, or any motor oil (like 10W-40 or 20W-50) without moly as an additive.
Old 05-18-2010, 09:18 AM
AddictedUSAF
Thanks for the reply. I was thinking about amsoil 10W-40 or Super Shift Racing Transmission Fluid SAE 10W
Quick Reply: What weight is HD primary fluid???
