Oil Archive (no new posts) An archive of oil related questions and comments.
20-50w same as sae 50???
Old 01-07-2011, 06:57 AM
raidernut's Avatar
raidernut
raidernut is offline
Default 20-50w same as sae 50???
Local store closing, oil cheep. Wife bought up all Harley oil, I use 20-50w in my scoot, but she brought home SAE 50.
Whats the difference and can I use this in the engine or somewhere else.
Need some advice, thanks!!!
Old 01-07-2011, 08:34 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Big Kahuna HDF Member
Yeah, you can use 50w in the Summer. Just allow the bike to oil up for a minute at idle when starting. Do not use it under 40F. 20w50 pumps like a 20w when cold and thickens up to a 50w when it gets up to operating temperature while 50w is just 50w all the time. Under 40F it will have a hard time pumping and you will get lots of engine wear at start up.
Old 01-07-2011, 09:18 AM
raidernut's Avatar
raidernut
Awesome!! Thanks for the info!! Oil was cheap, so got a good deal on it!
Old 01-07-2011, 09:59 AM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
I'd suggest training yourself to ride real softly until the motor is real good and warm.
Not a bad habit with any oil choice, but more important with straight heavy.
Old 01-07-2011, 11:07 AM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
+1 I always let my bike warm up for 3-5 minutes when cold. It just runs better anyway.
Old 01-07-2011, 11:47 AM
Jim Kraft's Avatar
Jim Kraft
Jim Kraft is offline
The main reason for 20-50 is so your motor will turn over easier to start in cold weather. If it will start on straight 50 you should be OK. Just let it warm up a bit as said above. Good idea no matter what weight oil you are useing. The heavier weight oil is probably better lube when cold than the lighter weight, as all the parts are a looser fit when cold.
Old 01-07-2011, 03:06 PM
rh8234's Avatar
rh8234
rh8234 is offline
Close - but not quite correct. The 20w50 does not really "thicken up" when it gets hot. It just thins out less. When cold, 20w50 is similar in vescosity to cold 20w oil. When hot, 20w50 is similar to hot 50w oil. Hot 50w is thinner than cold 20w. Therefore, 20w50 "behaves" like 20w when it is cold, and it "behaves" like 50w when it is hot.
Old 01-07-2011, 03:19 PM
Faast Ed's Avatar
Faast Ed
Faast Ed is offline
.....as we slowly drift further,....... deeper ,...... toward an all out oil thread.
Campy Roadie (07-28-2017)
Old 01-07-2011, 03:21 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
Yeah, I know but I didn't want to get into the whole viscosity index improver discussion because it gets too technical and the guy just wanted to know if he could use the 50w but needs to understand it will not pump well under 40F and will pump slowly under 60F.
Old 01-07-2011, 03:22 PM
KBFXDLI's Avatar
KBFXDLI
KBFXDLI is offline
LMAO....
Quick Reply: 20-50w same as sae 50???
