Bad decision in Tranny?
My bike stripped down and parts at the paint shop now so I changed all the fluids. I put Royal purple in everything. 20-50 in the engine and ATF in the primary and tranny. I must have read something wrong in the past. From what I have been reading in here tonight it looks like I was wrong. I haven't tan it yet and will probably drain and change it this weekend when I get some time.
So with all this said, just to confirm my VTwin ignorance, ATF is bad in the tranny right? To thin? Redline shockwave a good alternative? Would Royal Purple 20-50 max-cycle be fine?
The 85w140 is thicker and will reduce gear noise. ATF is too thin for the trans but fine for the primary. +2 on the BelRay 85w140 gear saver...I used it and it is fine.
Could not find Belray or Redline yesterday so I put Mobile 1 80-90 in. I'll find some Belray or Redline for the next change. In the three holes I have Engine: Royal Purple 20W-50, Tranny: Mobile 1 Gear, Primary: Royal Purple Max ATF.
Talldog
03-23-2012 07:35 AM
muleman
11
08-10-2008 08:17 AM
