Oil Archive (no new posts) An archive of oil related questions and comments.
Ever hear of Dynacycle Oil?
Old 03-12-2012, 08:29 AM
h0gwi1d's Avatar
h0gwi1d
h0gwi1d is offline
4th Gear
Default Ever hear of Dynacycle Oil?
I put this in both my roadking and Dyna. I love it. If you are looking for a new oil, this is it.
http://www.facebook.com/pages/Dynacy...559058?sk=info
Dynacycle Oil, created in 2003, is a biker owned and operated oil manufacturer, located in central New Jersey, and they have a BIG product for 4-stroke engines.
Their product, Dynacycle Oil, is a top quality semi-synthetic 20W-50 Engine and Transmission Oil specifically formulated for V-Twin and XL engines although it can be used in all 4-stroke air and water cooled engines that require a 20W-50 motor oil.
Dynacycle Oil is guaranteed to reduce your engine temperature by up to 30°F over conventional oils and up to 15°F over most full synthetic oils thus extending your piston and bearing life. It's friction reducing formula increases oil pressure, horsepower, torque, and gas mileage! With your engine running cooler and an increase in oil pressure and horsepower, you will increase your MPG. In today's economy that means more money in your pocket, not in your tank!
BETTER PROTECTION:
Dynacycle Oil also has one of the best "Wear Ball Test" numbers in the industry with a 0.31, which beats the top 5 selling motorcycle oils on the market today. Years of independent testing has proven over and over that Dynacycle Oil will reduce friction and engine wear a minimum of 50%.
OIL SPEC's:
Dynacycle Oil exceeds all manufacturers spec's and will NOT void manufacturers warranties.
STANDARDS:
API SM/CI-4, SH, SG, CF, CD, JASO MA, CG-4
Dynacycle Oil is MANUFACTURED in the USA!!!
FIND A DEALER / RETAILER:
http://www.dynacycleoil.com/Retail_Locations.html
V_twins
Shovelhead
10-01-2020 03:32 PM
papaharhar
General Topics/Tech Tips
07-21-2019 07:46 PM
itellya
06-30-2012 07:24 AM
alyaseen
08-15-2010 08:40 AM
tatkin
05-30-2007 08:31 PM
Quick Reply: Ever hear of Dynacycle Oil?
