shovel oil cooler and external oil filter
I want to install a oil cooler and external oil filter which hose coming out of oil pump goes to oil cooler and oil filter
If your pump looks like this, there are two oil lines on top of the pump.
The outboard line is the supply, tank to pump.
The inboard line is the return, pump to tank. This is the circuit that you want to install the cooler/filter on. Most people set it up so that the oil goes through the filter before it is cooled, as it is theoretically easier for the pump to move hot oil through the filter...
