Oil Archive (no new posts) An archive of oil related questions and comments.
View Poll Results: A poll
Redline shockproof
22.97%
HD Trans oil
10.88%
Mobil 1 -75/90
16.06%
Mobil 1- other
4.88%
Amsoil
19.69%
Syn 3
10.86%
Bel Ray
4.77%
Dyna cycle Trans oil
0.11%
Rev Tech
0.68%
Other
9.10%
Voters: 5286. You may not vote on this poll
What TRANS oil do you use?
  #281
Old 01-20-2010, 07:57 AM
Diesel2's Avatar
Diesel2
Diesel2 is offline
big cahuna, you say 75W90 is a 50 wt oil but as I read it, it is only equal to a 15W40[40wt] oil. I will only use a 75W90 in the cooler weather and as it warms up run the 75W110 which is the same as Amsoil's 20W50 MCV oil in weight.The MCV and the 75W110 are so close in their weights. The gear oil meets a GL5 specs., I do believe, and yes the MCV only a GL 1. I was running the Amsoil MCV in the trans but will start to run their gear lubs from now on.
  #282
Old 01-20-2010, 03:36 PM
fripple's Avatar
fripple
fripple is offline
Bel Ray here
  #283
Old 01-26-2010, 09:12 AM
mjaw's Avatar
mjaw
mjaw is offline
Wink
I use Amsoil 75w110 severe gear oil in the tranny,20w50 in the crank and primary.
  #284
Old 01-27-2010, 08:08 AM
Diesel2's Avatar
Diesel2
Diesel2 is offline
I stand corrected as I red the Amsoil site again and their 75W90 is heavier then a 40 wt oil, but is not the same as a 50wt. It is in between the two wts of 40 and 50 oils.
  #285
Old 01-27-2010, 08:17 AM
Cedar Machine Service's Avatar
Cedar Machine Service is offline
1st Gear
Synergen Syngear 2 in the tranny. Best stuff on earth. Also, use their 15w50 synthetic in the engine and Supershift in the primary and the bike runs 20 degrees cooler. Noticable difference.
  #286
Old 01-29-2010, 10:23 AM
jgc 89's Avatar
jgc 89
jgc 89 is offline
i run lucas 75 /90 syn
  #287
Old 01-29-2010, 08:29 PM
Rockyriver's Avatar
Rockyriver
Rockyriver is offline
I run Drag Specialties 85W/140 Transmission Oil for Big Twins.
http://www.dragspecialties.com/fatbook/13/131/7704240
X
  #288
Old 02-14-2010, 01:13 AM
Kenton Kyle's Avatar
Kenton Kyle
Kenton Kyle is offline
4th Gear
Smile Changed to Bel Ray with good results
Ran HD semi-synthetic for the first 92,000 miles. noticed a small drip of trany fluid on the garage floor whenever the bike sat unridden after a week or so. Switched to Bel Ray, runs good, smooth, quiet, and no more drips.
  #289
Old 02-16-2010, 11:24 PM
NorCal Dog's Avatar
NorCal Dog
NorCal Dog is offline
i runs Redline Shockproof Heavy in the tranny
  #290
Old 02-20-2010, 09:06 AM
BLACK BAGGER's Avatar
BLACK BAGGER
BLACK BAGGER is offline
Default Oil board ?
CHECK THIS OUT I SAW IT ON ----http://www.oilsandlube.com ---hope it's some help..
Quick Reply: What TRANS oil do you use?
