Harley Davidson Forums
Harley Davidson Forums - Harley Davidson Classifieds - HDForums.com Photo Galleries - Create an Account - Harley Davidson News
Go Back   Harley Davidson Forums > General Harley Davidson Tech Forums > Oil and Oil related topics
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Oil and Oil related topics A place to post your oil related questions and comments.
Sponsored by: Motorcycle Oil Site
Welcome to HDForums.com!
Welcome to HDForums.com.
View Poll Results: A poll
HD primary oil #99887-84 (old style) 286 13.05%
Syn 3 368 16.80%
Amsoil 526 24.01%
Bel ray 31 1.41%
Rev tech 24 1.10%
Dyna cycle 4 0.18%
Redline 188 8.58%
Mobil 1 486 22.18%
Doesn't matter 68 3.10%
other 210 9.58%
Voters: 2191. You may not vote on this poll
Thread Tools Search this Thread
  #121
Old 02-18-2009, 06:44 PM
bax467's Avatar
bax467 bax467 is offline
Prospect
i dig my redline mtl. gives much better clutch feel than the grabby 'ol formula plus. before i was always thinking my clutch needed adjustment. now, despite the weather and how long i've been in stop and go, it stays ultra consistant.
This ad is not displayed to registered and logged-in members.
Register your free account today and become a member on HD Forums!
__________________
2008 Black Pearl Fat Bob
  #122
Old 02-22-2009, 07:52 AM
aeproberts aeproberts is offline
Hang Around
I am a noob when it comes to Harleys. I have a Sportster, and in my case the primary and transmission lubes are the same correct?
  #123
Old 02-22-2009, 09:21 AM
Gary7's Avatar
Gary7 Gary7 is online now
Quote:
Yes, the primary and transmission on Sportsters share a common sump and use the same oil. This limits your choices. You don't want to use a GL-5 gear oil, and you don't want to use ATF. Harley's Formula+ is probably the best all around fluid for the Sportster transmission.
__________________
2009 FXDC in Vivid Black | CC Dyno Power mufflers | FLSTF 7" headlight | CVO Dyna seat | 4" Deluxe pullback risers | Black forward controls | Landmark shift linkage | LRB Z Plus pads | Nightrider 02 IEDs | Sputhe Positrac ...
The Super Glide: Showing shock and kicking ass since 1971.
  #124
Old 02-22-2009, 09:32 AM
OldFenderGuy's Avatar
OldFenderGuy OldFenderGuy is offline
As far as the combination primary/tranny on the Sportsters, many that I know (including myself) run the Mobil 1 75W90 gear lube without any problems at all.
Some of these bikes have well over 50,000 miles on the ticker, and no one has experienced any problems at all with the clutch pack.
Mobil 1 75W90 synthetic gear lube does have a API GL-5 rating.
Also, many think that 75W-90 gear lube is much to "thick" to use in a primary, but as you can see from the below chart viscosity of motor oil and gear lube is rated differently.
75W90 gear lube has about the same viscosity (thickness) as 20W50 motor oil.
__________________
"Magna Res Est Vocis Et Silentii Temper Amentum"
(The Great Thing Is To Know When To Speak, And When To Keep Silent)
And By The Way; I'm Not Your "Bro"..
  #125
Old 02-24-2009, 03:54 PM
Gary7's Avatar
Quote:
Originally Posted by Gary7 View Post
With a VI of 139, a vis at 100C of 20.0 cSt, and a pour point of -60F, this is a synthetic fluid, I don't care what Harley says. There is no way you can make an oil with those specs from even the best Group II hydrocracked base oils. It has to have PAO in it.
The specs I listed above have circulated on the Net for quite some time as being the "official" specs for Formula+ as published by the MoCo. This past weekend I conducted a freezer test on Formula+ and several other fluids, including motor oils, gear lubes and ATFs. After 12 hours at 0F Formula+ was opaque and would just barely pour. This tells me that pour point of -60F is total baloney, which may mean the rest of those specs don't apply, either. The fact that Formula+ turned opaque and almost solidified at a measly 0F tells me this is a conventional fluid made from Group I base oil. The PAO based 75w140 gear oil was still crystal clear after 12 hours at 0F and would pour easily. (And that's what's in my transmission now.)
It's no wonder the clutch is so grabby with Formula+ at cooler temps. I'm dumping it out of my primary next chance I get.
__________________
  #126
Old 02-24-2009, 04:12 PM
Gary7's Avatar
Quote:
Originally Posted by Vagabond View Post
Any one ever hear of this?
http://www.harleyhelp.com/oilbrand.html
It's a good thing he put that nonsense about synthetic oil and "bearing skate" down toward the bottom of the page or I would not have read most of his web site. What tripe.
__________________
  #127
Old 02-24-2009, 10:15 PM
old skool1983's Avatar
old skool1983 old skool1983 is offline
got amsoil in both holes in the sporty, come the summer i will be switch it gear lube for the primary since its connected to the tranny and it gets hot as haties down here in FL during the summer
__________________
  #128
Old 03-06-2009, 11:37 PM
garyhendley's Avatar
garyhendley garyhendley is offline
amsoil 20/50 works great in the primary-ride safe
__________________
06 Road Glide se stage 1 a/c se mufflers mustang seat custome chrome parts
Arlen Ness Hotshot ton of kuryakyn harley thunder star rims arlen ness / h-d a/c fullsac
true duals AMSOIL DISTRIBUTOR FOR SAN FERNANDO VALLEY
  #129
Old 03-07-2009, 12:09 AM
Gary7's Avatar
B&M Trick Shift is what's in my primary now. No more jump when you put it in first cold, and hot shifts are like butter. Nice linear clutch engagement, too.
__________________
  #130
Old 03-09-2009, 03:47 PM
eagle56 eagle56 is offline
Whats ATF like will it hurt my 08 fatboy .
Its embarassing have to freewheel it beore selecting 1st when cold to stop the heart stopping clonk
Tags
30, 9988784, atf, atf4, changing, davidson, evo, harley, hd, oil, oilharley, primary, revtech, running, weight, whats, wt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Advertising
Featured Sponsors
Vendor Directory
New Sponsors
Advertising Information - Harley Davidson Forums - Archive - Top
© Internet Brands, Inc.
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0
