turn signals
turn signals
Hi all would anyone know on a 1994 ultra classic besides the turn
Signal module do they also have a flasher relay located
On the bike as I found it strange even with the turn signal module disconected that the left handside would still flash but you would have nothing happening on the rightside
Its a weird one
Its a weird one
You're in the Oil forum here, so you are not going to get much response!
The turn signal module does everything. On my 1990 it flashes left and right, also when pressing both flasher buttons it flashes them all. So it is indeed weird if the left side flashes when the module is disconnected. If your bike is new to you there may be some strange electrical things going on, like someone wired in a flasher unit?
