Oil Archive (no new posts) An archive of oil related questions and comments.
1991 fxr oil filter housing
Old 08-06-2013, 03:40 PM
bigitybam's Avatar
bigitybam
bigitybam is offline
Stage II
Default 1991 fxr oil filter housing
i recently picked up a 1991 fxr and there is a leak from what appears to be the oil filter housing. when i reached to check the tightness of the filter the whole housing moved quite a bit. obviously this is not normal. how do you tighten the housing and are there any gaskets or parts that should be replaced while doing this repair? any feedback would be very helpful. thanks and safe riding!
Old 08-12-2013, 09:17 AM
grbrown's Avatar
grbrown
grbrown is offline
Received 2,851 Likes on 2,419 Posts
The filter housing is a simple alloy casting held on with a single bolt. You should be able to see the head of it on the swingarm mounting, at the rear of the tranmission casing. I only recently fixed mine. I suggest removing it, to clean up the threads, then loctite the bolt back in.
If you don't have one I can heartily recommend the factory service manual, available from your local friendly dealer!
Suziedestroy
EVO
15
04-24-2019 08:55 AM
brad75raiders
EVO
04-04-2016 12:28 PM
convergecult
Evo Era Parts
03-04-2013 09:32 PM
bigbud
Welcome Area Only
10-01-2012 10:55 AM
harleyguy5571
EVO
05-01-2009 08:46 AM
Quick Reply: 1991 fxr oil filter housing
