Oil Archive (no new posts) An archive of oil related questions and comments.
greasing the steering head
Old 01-10-2014, 03:44 PM
flicksport1200's Avatar
flicksport1200
flicksport1200 is offline
Default greasing the steering head
the service manual calls for harleys special purpose grease to grease the neck has any one used anything else, is there any other grease that is compatible with the h-d spec. purpose grease????
Old 01-10-2014, 04:32 PM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is online now
Received 8,482 Likes on 4,605 Posts
I repack the steering head bearings about every 7-8 years on my Softail, with wheel bearing grease.
If you look up that special purpose grease, it says it is for `97 and later .
That`s funny because the same steering head bearings have been used for over 50 years...
It is thinner so that it can be pumped into the steering head with a grease gun on the bikes that have grease fittings...and then run out all over the front fender on a hot day...
I recommend wheel bearing grease.
Old 01-10-2014, 05:07 PM
cvfd17's Avatar
cvfd17
cvfd17 is offline
Lucas red and tacky....
Old 01-24-2014, 06:30 AM
oct1949's Avatar
oct1949
oct1949 is offline
bought a tube of the HD neck bearing grease and another grease gun,
been using it for 6yrs now and I grease the neck bearing once in the spring..
pump grease in till it comes out top and bottom of the neck,, wipe excess off and then wipe it again later.
never had any to leak or run down on front fender,,
It was about $8.00, 6 yrs ago so it's gonna be more now (that's what, $1.00 or less a yr for the grease) and I still have maybe 1/2 tube left. At least I don't have to try to find what's close to it in another brand..
Old 03-02-2014, 09:06 AM
ppd1107's Avatar
ppd1107
ppd1107 is offline
2nd Gear
I used Green Grease which is available at autozone. It is compatible with most types of grease and does not run in hot warther
Old 04-15-2014, 07:56 PM
nervous's Avatar
nervous
nervous is offline
So. I have my new to me 09 Road King home for a couple weeks now and Saturday I found great globs of grease sitting on the lower triple clamp which surprised me. I am assuming at this point it's a result of some over zealous lining.
You all agree?
Attached Thumbnails greasing the steering head-image-469504287.jpg   greasing the steering head-image-2635016538.jpg
Sturgis67
08-28-2017 10:42 PM
anthony_b.
06-26-2013 06:57 AM
Rickr01
12-27-2011 11:59 AM
gilmour68
08-12-2010 04:58 AM
TalkLikeAPirate
10-08-2006 01:43 AM
Quick Reply: greasing the steering head
